handirifle
Veteran Member
Some months back, I added a proper oil tank, and filter, to my splitter, but now I have a leak. It leaks around the spin on filter, and I have tightened it with a oil filter wrench, much tighter than I do, say on my car or truck. Still leaks,
On my valve, the line from the "OUT" port on the valve, goes to the filter and back to the tank. I assume it's correct?
Could this be a leak inside the valve causing too much pressure? I had this leak when it was just sitting there, too. I used the filter that came with the filter housing. Kinda stumped here.
I noticed one hyd line has developed a leak at the fitting, and most of the other high press lines are old, so it's no surprise there, but the filter leaks bugs me.
