Spout fell in fuel tank, can't get it out - OK to use tractor?
   / Spout fell in fuel tank, can't get it out - OK to use tractor? #21
does it have a catch screen in it?
Yes, it does have a screen.
The wide mouth diameter is about 8 inches (give or take). The screen is at the bottom where it necks down to an inch (give or take) diameter.
That necked down diameter doesn't slow the flow too much either, so 5 gallons can flow reasonably fast.
Thanks for all the advice so far! Seems like the general consensus is it will not do a great deal of harm...
Once you run the tractor low on fuel (or drain the tank), use a flash light and inspection mirror (use a couple wire ties to strap the mirror to your wrist...leave it loose enough on your wrist to cut off, but not so loose it'll slip over your hand) to locate the spout...then you should be able to fish it out with those mechanical fingers (tool you bought).
Worst thing that could happen that I can think of (until you get it out) is the fuel level float might get jammed up. I doubt there would be any real damage though.
We went out and bought a flexible inspection mirror today...Will try that.
I have got to ask this sorry::eek: Why are you all still using the fuel spouts when there have been so many posts about them falling into the gas tank? Every since these enviromental fuel cans came out is when all this started with the silly slip on spouts that always fall off sooner or later.
Actually, I never had any problem with the spouts on the newer cans...This was an older can with a screw-on spout...
question- which part of the spout did it fall in? The whole thing? :confused:
Another question- Why did you drain it since the BX has a irregular shaped tank? I would've filled it 3/4's full and THEN feel around for the spout. Its plastic after all, it might float- but then this post might show my ignorance- I havent tried to see if plastic will float in oil like it does with water.
Yup, the whole thing. Yeah, we are going to try to fill it some and then tilt the tractor to float it over.
   / Spout fell in fuel tank, can't get it out - OK to use tractor? #23
Sorry, I just figured it was one of those enviro spouts that so many of the guys have had trouble with.. That is what I get for jumping to conclusions!
James K0UA
James K0UA
No problem. ;)
   / Spout fell in fuel tank, can't get it out - OK to use tractor? #25
I bought a garden tractor for parts from an owner who said it wouldn't run right. It ran fine sometimes but then would stall and wouldn't start.
When I dumped the old gas, out came a little plastic piece that came off a plastic fuel can.
Whether your tractor has problems or not, it might be best to retrieve the spout, for your peace of mind, if nothing else. By the way, it's now 8 yrs later and I still use the garden tractor - runs great without the little plastic fuel tank plugger!
   / Spout fell in fuel tank, can't get it out - OK to use tractor? #26
James K0UA
James, even though, in this case it was an older can...you did bring up a good point about those push on spouts. No doubt in my military mind, folks have dropped them in tanks as you described.
   / Spout fell in fuel tank, can't get it out - OK to use tractor? #27
I had one drop into my tank as described the new cans are slow to drain and yes I should have pushed the spout on tighter. Since then, I've installed vents into the cans.
   / Spout fell in fuel tank, can't get it out - OK to use tractor? #28
Look at the bright side.... I once installed a turbine pump at a new Chevron gas station, and when the inspector leaned over the hole, his cell phone fell out of his pocket and went to the bottom of a filled 5,000 gal unleaded fuel tank.
We all laughed, and I asked him for his cell phone number .. so i could call his phone and see if the tank would explode HEHE
He flipped me off.
   / Spout fell in fuel tank, can't get it out - OK to use tractor? #29
Don't think I would worry too much about it. If she starts acting like she's starved for fuel it meas you can locate it on or near the pick up spot.
   / Spout fell in fuel tank, can't get it out - OK to use tractor? #30
G'day doubt it will give you any grief I recently had the tank out of a machine here and the owner ( 2nd one ) asked if i could get the plastic spout out he dropped in there 3 or 4 years earlier, he was most surprised when i found 3 as he swears he had only ever lost one. Prob came from the prev owner some 10+ years prior
Jon
20 ft. Shipping Container (A53117)
20 ft. Shipping...
78in Screening Bucket Skid Steer Attachment (A51691)
78in Screening...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A51694)
2009 Skeeter SL190...
2009 Chevrolet Traverse LS SUV (A51694)
2009 Chevrolet...
2018 International Durastar 4300 Forestry Chipper Bucket Truck (A51692)
2018 International...
2017 Land Rover Discovery SUV (A51694)
2017 Land Rover...
