Sprayer Malfunction
   / Sprayer Malfunction #11
Another idea ... sometimes those rollers in the pump stick ... loosen the bolts on the back add a few drops of oil and hand turn it.
Just a thought before you go out and buy a new pump ...
   / Sprayer Malfunction #12
mburke
(if blueriver's plan doesn't work...... :) )
Then I suggest tear it down and put a repair kit in.
Rittenhouse | Repair Kit for Hypro 6500 Pump - 3430-0380
is one parts place for a kit. Repairing the roller pump after not storing it with oil in it was often the routine. I have a 12v pump now.
   / Sprayer Malfunction #13
I fill the pump with straight antifreeze after I'm done using it. As others have suggested, you night have a stuck roller or two.
Have you tried turning the pump shaft by hand? It should turn freely with no binding.
Thanks for all of the suggestions.
I worked on the sprayer today - and figured out that the pump had indeed seized up. The PTO connector had actually spun on the pump shaft, and the set-screw had etched a circle in the shaft (wearing through the flat part of the shaft.
I replaced the pump, and everything worked fine. I probably could have rebuilt the old pump, but it was in pretty bad shape, so I tossed it.
   / Sprayer Malfunction #15
as stated above fill that pump with anti freeze when you store it even in the summer. It will last a lot longer.
2016 Ford Explorer...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
TEST YOUR BID BUTTON! (A52706)
TEST YOUR BID...
12ft Heavy Duty Aluminum Ramps (A55301)
12ft Heavy Duty...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2012 CATERPILLAR 259B3 SKID STEER (A52705)
2012 CATERPILLAR...
