Spring Plow/All Purpose Plow..whatever you want to call it
   / Spring Plow/All Purpose Plow..whatever you want to call it #1
Sassi
Perry, Georgia
Kubota L3240
I recently bought an all purpose plow. It goes by a number of names. I bought it because it is as the name infers an (all purpose) implement. I grew up using and old Ford/Ferguson tractor, and one of these plows was used extensively around our farm.
I am using it right now to break up Georgia red clay so I can pick the dirt up easier with my FEL. Later on I will use it to bust up clots of dirt when I plow a section that I plan to plant in fescue for our farm animals to graze on.
Anyone else using one of these plows?
   / Spring Plow/All Purpose Plow..whatever you want to call it #2
A picture would help.
   / Spring Plow/All Purpose Plow..whatever you want to call it #3
Is this what your refering to ?
Boone
Thank you for putting in a picture. Yes this is what I call an all purpose plow! Others may call it a spring plow, rip plow, or even another name that I am not familiar with.
   / Spring Plow/All Purpose Plow..whatever you want to call it #5
Isn't that a cultivator, from the pic angle it looks similar to my one row cultivator.
   / Spring Plow/All Purpose Plow..whatever you want to call it #6
These are usually heavier than a cultivator but can be used as one if the shank spacing is easily adjustable. I use my one row cultivator for tillage in the spring to breakup the winter hard pack and mix in fertilzer & compost, then move the center shanks back out to straddle the row for cultivating. I have the County Line from TSC.
The one that I just bought had the shanks farthest out on each side setup with sweep bottoms installed. The old gentleman was using it as a two row lay off plow in the spring, for his garden. He then moved the shanks around and made it into a cultivator.
6ft Back Blade (A47809)
6ft Back Blade...
2002 KENWORTH T800 TANDEM AXLE CAB & CHASSIS (A43005)
2002 KENWORTH T800...
AGT Mini Excavator QNT50R (A47809)
AGT Mini Excavator...
Falcon Asphalt Trailer (A45336)
Falcon Asphalt...
48 HENDRIX CONSTRUCTION BUCKET (A47001)
48 HENDRIX...
2013 Kubota KX018-4 Mini Excavator (A47809)
2013 Kubota...
