Spring Plow/All Purpose Plow..whatever you want to call it
   / Spring Plow/All Purpose Plow..whatever you want to call it #1
Sassi
Perry, Georgia
Kubota L3240
I recently bought an all purpose plow. It goes by a number of names. I bought it because it is as the name infers an (all purpose) implement. I grew up using and old Ford/Ferguson tractor, and one of these plows was used extensively around our farm.
I am using it right now to break up Georgia red clay so I can pick the dirt up easier with my FEL. Later on I will use it to bust up clots of dirt when I plow a section that I plan to plant in fescue for our farm animals to graze on.
Anyone else using one of these plows?
   / Spring Plow/All Purpose Plow..whatever you want to call it #2
A picture would help.
   / Spring Plow/All Purpose Plow..whatever you want to call it #3
Is this what your refering to ?
Boone
Thank you for putting in a picture. Yes this is what I call an all purpose plow! Others may call it a spring plow, rip plow, or even another name that I am not familiar with.
   / Spring Plow/All Purpose Plow..whatever you want to call it #5
Isn't that a cultivator, from the pic angle it looks similar to my one row cultivator.
   / Spring Plow/All Purpose Plow..whatever you want to call it #6
These are usually heavier than a cultivator but can be used as one if the shank spacing is easily adjustable. I use my one row cultivator for tillage in the spring to breakup the winter hard pack and mix in fertilzer & compost, then move the center shanks back out to straddle the row for cultivating. I have the County Line from TSC.
The one that I just bought had the shanks farthest out on each side setup with sweep bottoms installed. The old gentleman was using it as a two row lay off plow in the spring, for his garden. He then moved the shanks around and made it into a cultivator.
2005 Mitsubishi Fuso FE84D Auto Crane 3203 PRX 3,200 LB Crane Utility Truck (A59230)
2005 Mitsubishi...
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
Case 1083 20ft Corn Head (A56436)
Case 1083 20ft...
KJ 20' Metal Farm Driveway Gate (A53314)
KJ 20' Metal Farm...
