spring starter
/ spring starter #1
Richard R.
Molino FL
2000 ford/ bushhog loader, 3203 john deere, 5035 mahindra ML130 FEL
has any one ever heard of a spring starter for an Mahindra. I have the 4 cyl 5035
/ spring starter #2
Never heard of it, Google showed me what it is. Spring starters Simms, Lucas, CAV mechanical starter motors from Kineteco Home Page
/ spring starter #3
this type of starter was used a lot on european models years ago very tricky to work on are you having problems with the starter if so just a few miles from you in pensacola is a place called b/m auto phone number 850-434-0897 ron davis is the owner he can help you there is a good chance you can get a regular solenoid type starter that will fit by some chance can you post a picture of the starter.
/ spring starter #4
Does your tractor actually have one or are you just curious?
These starters exist in the poorer parts of the world where people cannot afford batteries.
You crank for a while to build up energy in the compressed spring which you release to turn over the engine.
It is an upgrade in technical terms from the hand crank.
The other alternative is a heavy flywheel which you use a crank to spin up to speed and then there is a mechanism to connect the spinning flywheel to the engine crankshaft.
Saw guys on TV starting a rebuilt Tiger tank which had this type of system
Dave M7040
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
NEW WATER PROOF/FIREPROOF FIRST ALERT SAFE (A64281)
NEW WATER...
Hays LT1 Tender (A61307)
Hays LT1 Tender...
UNUSED MOWER KING-AGT SAII100 (A64281)
UNUSED MOWER...
Spartan SRT-XD Zero Turn Mower (A66285)
Spartan SRT-XD...
2019 Lynco Mini Mover Aircraft Tug Cart (A61567)
2019 Lynco Mini...
