Kerrminator said:
Can any one direct me to a resource that explains how to create a nice flowing creek out of a underground spring that surfaces out of a hole in the ground and saturates a wide area? Would it be best to have a pools to have a small resevoir of water as it disseminates down the hill.Keep in mind this project is all hand dug.Thanks.
Hi Kerminator,
I don't know the answers to your question, but have been developing a spring on my place. Work is still in progress & we have been flying by the seat of our pants, but am pleased with the progress.
1. Installed a 6' diameter fiberglass tank over it with pea gravel around.
2. Flows around 3 to 4 GPM depending on water level. This is now, during one of the dryest years we have had.
3. Installed a 2500 gal storage tank & started watering lawn from this.
4. Installed an additional 10,000 gal storage tank (tanks were free)
5. Spring started making a small pond outside the casing and would run back inside when water level was pumped down, so we have started making pond larger as we have time.
6. Have started putting in a lawn irrigation system, so far about 50 heads. Pump will run 20 to 25 heads at once.
7. I think the spring produces around 4/5 thousand gallons per day & we now have around 20,000 gal storage, tanks plus pond.
8. We pump from the spring to storage tanks with a 1 hp swimming pool filter pump and pump from the tanks to the lawn with a 2 hp 50 gpm pump. It is all automated. Spring keeps tanks full, if there is any water in the spring. We have much more we want to do, but it is beginning to look like a successful project.
