Sprinkler system
/ Sprinkler system #11
When I put mine in a few years ago I came upon this site web page. It was the best site I found bar none.....even the Toro and Rainbird stuff. The guy is good!
Good luck!
/ Sprinkler system #12
I used the same site. Forgot the name though. I am a civil engineer and his theories/principles are very good and accurate.
/ Sprinkler system #13
You need both, flow and pressure. Low flow, and you can only run a single sprinkler or two. Low pressure, even with flow, and the sprinkler will not operate.
Some heads only need 15lbs pressure to run, like the Rainbird or Toro spray heads. A 15' radius spray head may suck up some water flow though... On the other hand, too much pressure is bad. A spray head made to run 15-30 psi will mist instead of spray if you run it at 45psi.
Rotors and impacts like both flow and pressure. Some want 60, 70, even 100psi. And, they want 15, 20, or more gpm.
There have been some good points in this thread. Head to head coverage is important, as is working with obstructions like trees.
One thing I see a lot that causes problems, is mixed heads on a circuit. Don't mix spray heads with rotors and impacts on the same circuit. They put out different volumes of water, and will cause fits trying to balance coverage. Either run all spray heads, all rotors, or all impacts on a single circuit.
As long as you're trenching, add some main lines too. I like to add hose bibs around the property.
Another thing I see is people tapping the hosebib on the back of the house for thier backyard water system, when the main connection is out front. What they don't realize is inside thier house, the water pipe drops to 1/2" which does not flow as much water. And, lots of time you can hear the water flow thru the house...
Go to a irrigation suppply house, like Greenmark or John Deere Landscape. They will have the Toro, Rainbird, Irritrol manuals(and other brands). The manuals have a lot of good info on them, about head selection, pipe size selection, friction loss ect.
/ Sprinkler system
My 3/4 hp pump can easily run 4 impact sprinklers. Each will cover about an 80' diameter circle. I have the advantage of only pulling a 10 foot head, though.
I run 3/4" rubber hose off the pump to the first sprinkler, and then I run normal 5/8" to the second sprinkler on each line. Sometimes I am running 150 foot of hose. The 3/4" hose is worth the cost. I also really like the rubber hose.
2012 HEIL (A60736)
2012 HEIL (A60736)
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
AGT Industrial ExRC54 (A60463)
AGT Industrial...
Caterpillar 906M (A53317)
Caterpillar 906M...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
2017 FORD F-150XL CREW CAB TRUCK (A59823)
2017 FORD F-150XL...
