Sprocket for snowblower chute
   / Sprocket for snowblower chute #21
I tried. The sprocket pitch comes out to be roughly 1 1/8 I keep finding stuff that will work with 1 1/4 or 1? The snowblower is made my Braber equipment sold by northern tool. The rotation kit that they sell for the snowblower is too much money and I know with enough research and questions asked I can make it happen for half of what they want for it.
Think outside the box. Think bicycle.
Amazon.com: bicycle sprocket
   / Sprocket for snowblower chute #22
I would go higher up at Northern and tell them you can't get "parts" for stuff they sell.
I have seen cases where a chain is welded to a frame and a sprocket travels on it. Maybe you could wrap and weld a chain around the chute if your chute is stable enough. Possibly use some idlers at two corners and the motor with sprocket at the third point.
   / Sprocket for snowblower chute #23
I was thinking the same. I have seen the type that wrap a cable around the chute and wind it in or out with a hand crank. If the OP has a hydraulic motor and 40 pitch chain, he could make a loop around the motor sprocket and then do 1 wrap around the base of the chute. Affix the two ends of the chain to the chute, and now you have your own virtual sprocket.
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A53843)
2006 V.E...
2015 CATERPILLAR TL943C TELESCOPIC FORKLIFT (A52707)
2015 CATERPILLAR...
2014 Nissan Murano SUV (A55853)
2014 Nissan Murano...
BrushFox HD-78STD 78in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox HD-78STD...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
