square baler knotter problems
   / square baler knotter problems #11
I have a New Holland hayliner 273 Problem with twine breaking after it ties the knot behind the knotter.
   / square baler knotter problems #12
I believe there are 2 types of twine one is for square bales, some round baler twine won't work. We had same problem
   / square baler knotter problems #13
Hey, hope you get a good reply to your question, I have same issue, and now hay season is upon us again.! tks, JS
   / square baler knotter problems #14
Bales to tight ? With startup loosen adj on side of bales and after a few bales retighten again
   / square baler knotter problems #15
Well, Tonite will be the inaugural starting of the NH 269 since the plunger rebuild. I've been rereading all about the timing and knotter trip lever settings. I'll have reset all the settings. Hopefully I'll get some bales made this year. I'll report back. bjr
   / square baler knotter problems #16
Were using a NH 500 and only the center twine brakes loose after about 100 bales we've replaced
the cutter and twister and several other parts but it still brakes the twine,any thoughts.
   / square baler knotter problems #17
Quality of twine? What brand are you using? I use Bridon 9600 in my Hesston. Tried Tighton and others and they broak just as you described. It also may be you tension disks are to tight, or look for a bur on the wiper arm.
Also if the roll was exposed to sunlight for too long, it can be weaker on the side exposed to the sun.
   / square baler knotter problems #18
You got it,it was the wiper arm it was worn out and very loose works great now thanks
2015 F-550 Bucket Truck. (A52748)
2015 F-550 Bucket...
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
New 12x20 Steel Carport (A50774)
New 12x20 Steel...
