squeaky wheel with no place to grease.
   / squeaky wheel with no place to grease. #1
gsxrsquid
S-370D Left rear wheel squeaks. No place I can see to add grease. I am wondering if it is the brake dragging. Do I have to pull the hwole axle housing to check the brake? I never really use the brakes anyway. I think I need a return spring but will need it to cool down to check. It is already summer in NW Bama.
   / squeaky wheel with no place to grease. #2
Brakes on the front wheels?
If there's no grease points I assume it's 4WD, is it supposed to be oil bathed and if so is it?
Yes 4 WD. Grease point on the front. I haven't had it long so I need to find out where the points are for adding fluids. Looks like I am going to have to start taking things apart.
   / squeaky wheel with no place to grease. #4
Rear wheel bearing is generally lubricated by the transmission fluid, kind of like a car or truck. If it's getting hot it may well be a brake dragging. Contact Valley Power and they can provide info and possibly a manual. They're also a source for parts. They're in Roanoke, VA.
Thanks. The more I think about it, it is probably the brakes. I will open them up and see what wonders are inside. :D
148 Inch Roll Up Garage Door (A55852)
148 Inch Roll Up...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2024 John Deere 6110M MFWD Tractor (A53485)
2024 John Deere...
2018 CATERPILLAR 259D SKID STEER (A52707)
2018 CATERPILLAR...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
2023 Kubota SVL97-2 Compact Track Loader (A55314)
2023 Kubota...
