Squirrel cage fan wiring
   / Squirrel cage fan wiring #1
Firefighter912
GA
JD 5205 MWFD
Trying to get me a better fan for my shop. I need some help on the wiring.
I am assuming the Black is hot, the other colors are for the speed, and the green is the ground.
I have an extension cord I am using to wire it up and its colors are white, black, and green
Here are some pics.
Thanks 20190526_201907.jpg20190526_201911.jpg20190526_201916.jpg20190526_201907.jpg20190526_201911.jpg20190526_201916.jpg
I have the orange to white. Black to black. Green to green. Is that right?
   / Squirrel cage fan wiring #3
I'm no electrician but according tho the wiring diagram I would hook up
White on the cord to orange on the fan
Black on the cord to - black on the fan for high
- yellow on the fan for medium
- red on the fan for low
Green on the cord to any metal component on the motor housing. Not on the fan housing as it could insulated from the motor.
Ok sounds like how I got it. Here I go! If I dont respond back..you know I got fried!
It works. But looks like I may just get a big shop fan. Doesnt throw out like I would want it.
   / Squirrel cage fan wiring #6
I read somewhere those squirrel cages need some kind of blockage to really push air. You should YouTube it. It matters somehow. Good luck
I covered the hole up but it still doesn't push enough in my 30x30 shop with no insulation. Lol.
   / Squirrel cage fan wiring #8
I was able to get a couple of large fans in roll around cages from work. They turned out to be a pain in the axx for me. The tops were clutter catchers and then stuff would fall off when they needed to be moved and they were constantly getting in the way. Ended up giving both away to a friend and installed 3 commercial ceiling fans to replace them. Much better solution for me.
   / Squirrel cage fan wiring #9
I have two fans like you have and mounted one on a stand. Not much air and it gets very hot. Probably because of the airflow over the motor not being like designed inside a box like the air conditioner unit.
You might be better off with a stand alone squirrel cage type fan and mount a motor and run it by pulleys and a belt. I have two like that and one seems plenty for a 26x32 garage.
   / Squirrel cage fan wiring #10
How many HP & RPM's motor?
UNUSED Safety Work Gloves (A53117)
UNUSED Safety Work...
7022 (A50322)
7022 (A50322)
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
2014 John Deere 644K Articulated Wheel Loader (A51691)
2014 John Deere...
2023 BOBCAT T62 COMPACT SKID STEER TRACK LOADER (A53473)
2023 BOBCAT T62...
