started working on my free to me B7100HSD
   / started working on my free to me B7100HSD #1
brain55
Brentwood, CA
Took the wheels and tires down Saturday and had new tires installed at Les Schwab $550 later. And today I made all new hydraulic hoses for the loader. This tractor had sat for about 4 years without being started. It fired up first hit of the key, but when I went to lift the loader fluid sprayed out of the side of some of the hoses. Lucky for me, I stock the hose and fittings. It nearly depleted my inventory of 3/8" male npt hose ends and used 30+ feet of hydraulic hose. So I'll have to replace those, probably about $150 worth of inventory. Beats having to pay retail, or having to have someone make them for me. I should have the rest of the parts I ordered from Kubota in the next couple of days. It needed bevel case seals, new seat, battery, cables, decomp wire, etc., about $700 worth of cosmetic and mechanical parts. All together I should only have about $1500 worth of parts into it including the hoses and tires. I figure I should be able to sell it for around $4000, so for about 10-12 hours of labor I stand to make about $2500. I wish I could do that every week.
Brian
   / started working on my free to me B7100HSD #2
Pictures, before and after!
   / started working on my free to me B7100HSD #4
Took the wheels and tires down Saturday and had new tires installed at Les Schwab $550 later. And today I made all new hydraulic hoses for the loader. This tractor had sat for about 4 years without being started. It fired up first hit of the key, but when I went to lift the loader fluid sprayed out of the side of some of the hoses. Lucky for me, I stock the hose and fittings. It nearly depleted my inventory of 3/8" male npt hose ends and used 30+ feet of hydraulic hose. So I'll have to replace those, probably about $150 worth of inventory. Beats having to pay retail, or having to have someone make them for me. I should have the rest of the parts I ordered from Kubota in the next couple of days. It needed bevel case nseals, new seat, battery, cables, decomp wire, etc., about $700 worth of cosmetic and mechanical parts. All together I should only have about $1500 worth of parts into it including the hoses and tires. I figure I should be able to sell it for around $4000, so for about 10-12 hours of labor I stand to make about $2500. I wish I could do that every week.
Brian
Not real familiar with that model but do't sell too cheap - If it is 4WD with loader and in good running order you should be able to get more than 4K for it!
   / started working on my free to me B7100HSD #5
You lucky dog!! You know you aren't going to be able to sell until, you get some time with it. Say 3 or 4 years.
Here are your before pics. It will clean-up nicely. I was taught not to paint tractors before selling them, because a freshly painted tractor usually means somebody is trying to hide some bigger problem. I might go against that on this tractor, I think some fresh paint will make a huge difference.
Brian
Here are some progress pics.
Next step is painting the orange parts, then putting it back together.
Brian
   / started working on my free to me B7100HSD #8
Looks Sharp! How much time to disassemble like that? I really think if everything works well you can get more than 4K!
It took about 12 man hours, including 2 trips to the local car wash with the tractor. One with it all assembled and another when it was stripped down, plus another trip with the sheetmetal. We wiped it all down with lacquer thiner, scuffed it with scotchbrite and wiped it down again. I'm probably going to ask $5000 for it now, considering the extra work (about triple the hours I originally intended) and expense of all the decals and other small parts (I'll probably have about $2000 into it), but this machine will be practically like new. This machine was not used hard. The previous owner was a small nursery, they used it for mixing soil and pulling plant carts around. It only has 2400 hours on the meter, doesn't smoke, and the HST is tight.
Brian
JOHN DEERE 915 V-RIPPER (A52708)
JOHN DEERE 915...
1608 (A57192)
1608 (A57192)
2013 Haulotte 4527A (A57148)
2013 Haulotte...
2007 Hummer H3 4X4 SUV (A56859)
2007 Hummer H3 4X4...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
