Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 51,575
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
You got the same truck i do.
Ditto what mark said.
I used a 3/8 ratchet with a 6" and a 3" extension... now here's the deal... you put the 3" extension on first.. then the 6" then the socket.. if you do it the other way, the hump where the extensions meet hits the starter in a funny place and WON"T fit! 2 6" extensions won't fit either. You kinda have to push the trans cooler lines to the side about 1/4" and use the ratcher on the right side of the starter. Takes about 5 minutes of cussing.. a couple eye popping grunts and a skinned knuckle, then it comes off. that's the fun part. do make sure battery hot is pulled.. cuz now here's the good part.. starter will only slide back about 3".. but needs 3.5" to come out.. there is a bracket held on with 2 bolts that you gotta pull.. then the starter only has enough cable to slip out and you kinda got to hold it and then grab 2 nut driver to spin the nuts holding the solenoid and battery loop terminals off the top of it. Getting it back in is fun too!
a impact wrench will spin that nut off without using the screwdriver.. I do it to alternator pulley nuts all the time... use the screwdriver when torquing the nut with a TW.
soundguy
soundguy
Ok I need some help... I have a 1998 Dodge ram 1500 4x4 5.9 and I am in the process of replacing the timing chain. I have the thing pulled apart but I cannot get the Damper off the crank shaft. The big nut holding it on will not crack loose as the shaft just rotates when I torque it. Hayes says to remove the starter and wedge a screwdriver in the flywheel teeth to keep it from rotating...easy enough.. not! I cant get to the upper nut holding the starter on. Houdini must have put this thing on. There is not enough clearance to get a ratchet on the nut and the starter is only two inches away from the frame so a regular box wrench won't fit either. So how did you get the top nut loose? Any suggestions would be appreciated. What was supposed to be a 4-5 hour job is going on two days.... Thanks
