ottawarob
If the saw pulls easily it may be lacking in compression.
Doesn't pull that easily, my guesses are:
a) clogged up exhaust screen
b) carb problems
c) fuel cap vent or some fuel line leak
I had an old Homelite ;gave it away.Most frustrating saw ever.
Check compression.---If carb can't be set, then install a new carb. I put kits in mine, BUT every so often one came up that still didn't work right--Some of them are really hard to clean the small internal passages, forcing a replacement carb. thanks; sonny580
I picked up an old homelite XL12 saw. Nice little thing, I plan to use it for clearing underbrush. I found an old manual for it, where they say to start it, you should start it with the throttle in all the way and choke on. Is that right? I've had a hard time starting it, but up to this point I wasn't doing that. I'm going to pull the carburettor and clean it, because I've had a heck of a time starting it, but maybe I've just been starting it wrong.
