Starting issues with john deere 2040
   / Starting issues with john deere 2040 #51
I wonder how much that setup would cost? Ill also need to check if mines the model that will let me run it through the hood, because if theres a model that ran the exhaust down by the floorboards, then mine might not be capable of that.
To correctly change the types of mufflers on a JD utility 3cyl/4cyl tractors one also needs to change exhaust manifolds.
Just got it back from van wal and it started up no problem!!! Its a sweet tractor, but im not all that familiar with the different levers, as i usually drive a kubota thats a lot newer. All i pretty much know is how to drive it, not activate pto, lower or raise 3 point, or some of what the other levers do though.
   / Starting issues with john deere 2040 #53
How old are you??
Im 15, and if your just gona hate and tell me i need to get off, i dont really care, and if your cool with it, then thanks :)
I know not to use the trial and error methid with this stuff. The manual should give me some good info.... I hope
2010 Toyota Prius Hybrid Hatchback (A53424)
2010 Toyota Prius...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A54607)
2013 KENWORTH T680...
(2) ROLLS OF MISC CARPET (A54757)
(2) ROLLS OF MISC...
2007 JOHN DEERE 700J XLT CRAWLER DOZER (A52705)
2007 JOHN DEERE...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55218)
Galvanized...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
