Starting problem
   / Starting problem #1
dledbury
ford 1700 diesel
Hi all,
Borrowed a Ford 1700 diesel tractor from my elderly uncle. Started great the first time, but now since shutting it off I can't start it again. Has fuel, haven't run it anywhere near dry. I was told about a glow plug has to come on then go off before starting. Seems the minute I start cranking the light goes off and doesn't come back for hours. Any suggestions? Strawberries are coming today and need to till one more time before planting. Thanks in advance for any suggestions
   / Starting problem #2
does it turn off with a key? or do you pull a cut off lever?
   / Starting problem #3
I have a Ford 1600 that started hard. Your tractor probably needs new glow plugs. I changed mine and now it starts mint. Also, the throttle lever should be all the way forward. As soon as it starts, very quickly bring the lever to 1,000 - 1,200 rpm.
   / Starting problem #4
Do you need to turn the key to the LEFT and hold it for a minute before turning it to the right to start it. That is how our 1900 worked. On ours, the glow plugs were only on while the key is held in the left position.
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2012 ADDCO Arrowboard (A52377)
2012 ADDCO...
2019 John Deere XUV560E Utility Cart (A53421)
2019 John Deere...
2025 MS380R Mini Stand-On Track Loader Skid Steer (A53421)
2025 MS380R Mini...
2007 Ford F-250 Crew Cab Pickup Truck (A51692)
2007 Ford F-250...
