Steel Buliding Decaying!!
   / Steel Buliding Decaying!! #11
Thats those new termites , they love steel
   / Steel Buliding Decaying!! #12
You can easily cut it off with a cutting disk on a 4 1/2 inch grinder and then slide a longer piece under it that is about a foot longer. Shouldn't take very long or cost very much
Exactly , why make it complicated . It;s easier to cut that bad part off if you can remove the panel but don't bother if it looks like it will be a hassle. You can just remove the screws above the damage enough to pry up and get the panel up clear of the neighbors. Then cut across with a cut off blade on your small grinder. If you don't have one you could just go grab a 7 1/4" steel blade for your skill saw providing it doesn't have a plastic guard over the blade. Same goes for cutting the replacement if you have to. Tin snips just plain suck on corrugated steel although you can do it that way if you have to. Lap it, screw it down and you are done. Just make sure to have some safety glasses and gloves on while doing that cutting as those wheels throw a lot of debris.
   / Steel Buliding Decaying!! #13
I have the same problem with my 60' x 40'. The erectors (1991) allowed the insulation (held up by chicken wire) to go below the angle iron mounted to the floor and in places to the bottom of the sheet. When it rained, the insulation weeped the water upwards a few inches and rotted the sheet especially where the bolts go through the sheet into the angle iron on the floor. I have yet to decide exactly how I want to repair this.
Dale
   / Steel Buliding Decaying!! #14
There aren't many thing on earth that suck up, wick and hold moisture and water than that damned pink insulation. Those batts are ok inside a nice dry structure but do everything you can to keep it away from ground contact. From the look of your picture something salty did all that damage. If not I wouldn't doubt that the insulation had Isomething to do with it. Fromthe recent contractors bulletin boards they don't even recommend that stuff in basements of your house anymore, mainly due to mold.
I pretty much swore off the pink panter crap when I happened across a HVAC site that pros were discussing the various aspects of roll insulation. I don't remember the numbers but for actual R value goes absolutely to crap in the presence of a 10 mph wind. The pink panther never mentioned that in his ads:thumbdown:
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
INOP/NON- RUNNING 2013 Ford F-250 Pickup Truck, VIN # 1FT7W2A61DEA38762 (A51572)
INOP/NON- RUNNING...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
1273 (A50490)
1273 (A50490)
