steep slope, oil pressure
   / steep slope, oil pressure #11
While doing extreme 4x4 stuff (rock crawling etc) we would often have to winch up or strap down stuff that was too steep. While we talked about the possibility of losing oil pressure it was never an actual issue. Your tractor doesn’t see the extremes of 4x4 world.
So to answer your question. No I haven’t installed one on a tractor. But I have on several 4x4s with gauges and never saw an issue.
Oh hi, another rock crawler or a least used to be here.
I'd be more worried about losing my bladder contents on a tractor at angles like that. My rock rig is a whole lot more stable on slopes than any standard tractor ever could be.
   / steep slope, oil pressure #12
I frequently operate my tractor in steep terrain and was wondering how steep you can be without losing oil pressure?
Has anybody installed an aftermarket oil pressure gauge? There must be a place on the motor where the sending unit can be installed.
Thanks,
Russ
Any solution found to your problem? Have you installed an oil pressure gauge yet? I'm in the same predicament. I'm on very steep terrain. I haven't had problems yet....I just want to be proactive.
   / steep slope, oil pressure #13
I haven’t met a tractor or other vehicle made in the last 50+ years that doesn’t have an idiot light for oil pressure. I’m not discounting the concern- only trying to ease the worry. You will know long before you do engine damage.
   / steep slope, oil pressure #14
Thanks. Your reassurance does ease my worry.
   / steep slope, oil pressure #15
Only if you see the idiot light flashing, or hear the warning buzzer buzzing. You can also get a low oil pressure shutdown switch, which will kill the engine if the oil pump starts sucking air.....
that would be fun on a hill.... :eek:
   / steep slope, oil pressure #16
A lot will depend on the shape of your oil pan, my Oliver 1550 had a long shallow oil pan and working in the driveway you could see the mechanical gauge bounce some times I ran her a quart and a half over full till I tore it down to work on the head (valves) while I had the head off I cleaned up the crank a bit and put in rod and main bearings and new rod bolts. While I had it apart I added a deeper sump and lengthen the oil pickup tube. I run my IH 574 and the Branson 8050 a quart over full, I have checked the oil several times and have never seen any indication of it being churned or getting frothy as it could if the crank was splashing it to much.
   / steep slope, oil pressure #17
That 574 is the same as my on IH2500b industrial tractor loader. Mine was HST. Many times on my hills the hydrostatic low pressure warning light and buzzer would go off. Many times.
20ft Shipping Container (A51573)
20ft Shipping...
2018 Nissan Sentra Sedan (A51694)
2018 Nissan Sentra...
1977 GMC GENERAL TANDEM AXLE DUMP TRUCK (A52577)
1977 GMC GENERAL...
2001 HEIL PNEUMATIC CEMENT TRAILER (A52576)
2001 HEIL...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
