Steering leak 1971 Ford 2000 - replace oil seals?
   / Steering leak 1971 Ford 2000 - replace oil seals? #1
aschwerin
Eureka Springs, AR
1971 Ford 2000 diesel
I've had this tractor for a little while now, and I got around to checking the steering, and there was no fluid in the box. So I filled it up with 80w-90. In 2 days there was almost no fluid in the box, it all leaked down the sector arms.
Its got what I think is called power-assist...its got two hydraulic cylinders attached to the tie rods.
So I ordered some oil seals for the sector shafts. Took the arms off...and could not figure out how to remove the old seals. I took off the cover and adjusting screw assembly from the opposite side. I could tap the sector arms back and forth 1/2" or so, but they wouldn't come out.
So, is there some method I'm missing (the manual says they just pull out...not so...)
Or should I put the #00 grease in and save the oil seal parts for another decade....
   / Steering leak 1971 Ford 2000 - replace oil seals? #2
they do pull out.
And it's not 'power assist'. it's called.. ' power steering '.
The service manual shows how to dis assemble the steering box.
I don't mess with the power steering boxes, but for the sake of just pulling sector gears and whatnot.. they are the same as the manual boxes.
PS.. got a seal puller? you are doning way too much work.. you can just snatch those out grease and stack a couple new seals and go.
2005 Ford F-350 4x4 Service Truck with Crane, VIN # 1FDWX37P55EB97537 (A51572)
2005 Ford F-350...
John Deere 310K Backhoe (A51573)
John Deere 310K...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
2018 KENWORTH T680 SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2017 MITSUBISHI OUTLANDER SPORT (A52472)
2017 MITSUBISHI...
