Steiner 430 Max Diesel Hydraulic Issue
   / Steiner 430 Max Diesel Hydraulic Issue #11
Joshlee, I love my power-trac, much better than my old steiner. I got my steiner stuck in the snow more times than I wish. My power-trac just floats over the same spots my steiner got stuck in due to its flat underside. For me my power-trac is more versatile for what I use it for.
   / Steiner 430 Max Diesel Hydraulic Issue #12
Maybe im wrong but in looking at both a PT and Steiner..they dont seem to be in the same category...PT is more like a tractor isn't it..also hydro drive pto, as opposed to belt..just saying, also a PT doesn't look nearly as nimble and has a much higher psi contact patch. .just different machines for different jobs..
   / Steiner 430 Max Diesel Hydraulic Issue #13
They are awesome machines. You know how those pivot pins on the Steiner roll around when the front lift is working; my thought is that those holes on the mount/axel will get wore from all of the movement from the pins. Obviously there are no grease fittings either. The PT 425 has a bolt with a nylon lock nut, if I remember right? If so, does that roll around at all when you lift a heavy load?
Toro Dingo Mini Skid-Steer Mounting Plate (New/Unused) (A59225)
Toro Dingo Mini...
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
Poly Bristle Sweep, 78" x 8" (A59076)
Poly Bristle...
2011 BMW 328i Sedan (A56859)
2011 BMW 328i...
2009 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2009 Ford F-250...
Mini Plate (A57149)
Mini Plate (A57149)
