steve42rich
/ steve42rich #1
steve42rich
hubbard tx
165 massey ferguson
i have a massey 165 aD4-203 perkins with water in the oil and when you pull the dipstick out it blows alot of air and oil water mix i was thinking head gasket i just dont understand why so much pressure in lower part of engine.I can pull the oin pan and pressure up cooling system to check for leaks serial # 94-75751
/ steve42rich #2
Sounds like it is time for a rebuild. preasure getting buy the rings and blowing out of the dipstick. That is my idea.
/ steve42rich
yes i pulled the head and the 1st piston from the radiator is worn with alot of slack plus the sleev has sliped down 1/8 inch the other 3 pistons are realy tight so i think i will just have a sleev pressed in and a new piston with rings and go for it
/ steve42rich #4
If you selling it, that would be the thing to do. But if you are planning on keeping it for a while, it may benefit you to rebuild the entire engine. Be sure to send the head in to get it checked.............regardless of which way you go.
/ steve42rich #5
I agree with Don It is cheaper to do it now than later.
/ steve42rich
Yes i agree Don iam not sure the cost of rebuilding but most of the work i can do myself i just need help with that 1 sleeve pressing it in after that i can put it back together.that loose piston has some chunks taken out of it like somthing was between piston and the head but head is clean not sure
2025 GIDDY UP 7'X14' BLACKOUT XTREME CARGO TRAILER (A62130)
2025 GIDDY UP...
2008 Wabash National Dry Van Trailer, VIN # 1JJV281W68L109579 (A61166)
2008 Wabash...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
2213 (A62131)
2213 (A62131)
2009 Ford F-150 Pickup Truck, VIN # 1FTRF12W99KB57427 (A61165)
2009 Ford F-150...
