How difficult is it to finish the home inside and out? In our area vinyl siding is commonly used on the outside. Is it difficult to attach door casing and jambs? What about the baseboard trim? How is it attached? How are cupboards supported on the walls? These are a few things I have wondered about.
Not all interior walls of concrete homes are load bearing or concrete.
My home has three doors in concrete walls. Two out of the three were NOT properly installed. One was cut out using a carbide tipped hydraulically powered chain saw running on a steel rail anchored to the concrete wall and replaced with a new jamb (virtually a perfect fit) and since it is doweled to the existing structure it is plenty strong for a safe room.
The second bad frame was left in place and a new door (HD steel bored for three deadbolts, yes another safe room... we have two, on separate floors) and a door was custom modified to fit the frame. Kind of ironic and funny actually as the concrete guy who installed the second of the above mentioned disasters was highly amused when the ICF installer messed up one of the two doors he installed AND THEN I found his installation to defy door installation.
In both cases not enough bracing was placed horizontally inside the door jam to withstand the force of the concrete before it began to take a set. Every time I would suggest such an outcome I got the "We are the pros from Dover" speech.
The above described door frames were HD steel frames. Regular wooden frames can be put in concrete "door holes" by forming the door hole oversized to permit fastening rough framing wood to the hole (sized like a standard stick built door situation) and then installing the frame, jams, and casing in the routine stick built manner. Tapcon screws are one way to attach pressure treated wood to the concrete. (Pressure treated wood when wood touches concrete is a good idea.)
Typically the location of a kitchen's wall cabinets is known prior to pouring the concrete wall. You can inset pressure treated blocking (2x4 is sufficient) in the forms. Screw some screws through the blocking into the empty cavity into which concrete will be poured so that the concrete will grab the threads and the board will be secured. Alternatively (I like this better) you can rip the edges of the 2x blocking (pressure treated 2x4 or 2x6, whatever you like) such that the cross section (as viewed from the end of the board) is a trapezoid. Place the trapezoidal blocking into the formed wall cavity such that the wider dimension is inside the wall and the narrower dimension is flush with the forms for the inside surface of the wall. After the forms are pulled you have pressure treated wood embedded in the concrete wall. You will want two horizontal runs of this embedded wood located to accept the fasteners which hold the wall cabinets to the wall.
You don't really need full length horizontal blocking if you know were your cabinet's wall hanging fasteners will be with some precision. I'd use the full length ones so any screws at the height above floor of the blocking will hit wood, not concrete. You can use Tapcon fasteners and the supplied carbide bit to attach the cabinets to the concrete but... most cabinet installers are used to and set up for fastening to wood and may not be happy fastening to concrete. I have a pneumatic "T" nailer that shoots nails into cured concrete and it could be used for hanging cabinets on a concrete wall but it would not be my first choice.
I got lots of use out of the "T" nailer when I put 4 ft high wainscot over the concrete walls of my lower level. I used rough ERC (Eastern Red Cedar) slabs with the bark on for most of the covered walls and planed ERC for a guest room. From the 4 ft above floor level to the 9foot plus ceiling I used very short pile carpet glued to the concrete walls and trimmed around the edges with ERC.
HMMMM I posted a jillion pix at
South Central Oklahoma Farmhouse
But they seem to have fallen into the bit bucket or evaporated into cyber space when a NEW style forum application was instituted.
Pat
