Stiff 3PT Lift Arm Sockets?
   / Stiff 3PT Lift Arm Sockets? #1
Mayhem
Ransomville, New York
BX2200
For lack of a better description the implement end of my 3PT hitch arms where the balls are. They move very hard and make mounting equipment very difficult.Has anyone got an idea on how to free these up? I have tried lube with a ton of ELBOW grease, but they just won't free up. /forums/images/graemlins/mad.gif
   / Stiff 3PT Lift Arm Sockets? #2
I haven't tried it myself, but I wonder if some dry graphite would help???
   / Stiff 3PT Lift Arm Sockets? #3
Just be patient. They will eventually free up. Just keep them lubed with light oil, and keep a piece of pipe around to rotate them into position. The oil will attract dust and dirt and create a little play in the balls eventually. Also, there may be some paint on the balls that are causing them to be difficult to move.
Best of luck.
   / Stiff 3PT Lift Arm Sockets? #4
Every time I grease I splooge a little on those balls and wiggle them around. Now that the grease is worked in it keeps the water and ice out so the rust thing doesn't bind it up. At first I used WD40 on them because mine were stuck too. The WD40 worked to get them loose.
   / Stiff 3PT Lift Arm Sockets? #5
I have started using silicone lubricant for a lot of things. It doesn't seem to attract as much dust as WD40 and it is very slick. Perhaps some silicone to get them freed up a bit and then a light coat of grease now and then to keep them loose.
Bill Tolle
   / Stiff 3PT Lift Arm Sockets? #6
I removed the paint with a grinder equiped with a cotton pad and I put some grease on the balls. Now the balls rotate freely and it's a child play to connect implements. It took me about 15 minutes to do the job and now it works very well.
Man I've lubricated and wiggled till the cows came home and they just won't loosen. /forums/images/graemlins/mad.gif The balls are clean and shiney,not sure what the inside of the arm looks like.I'm going to keep lubricating them and working them around,but boy it makes it hard puting equipment on and off.
/forums/images/graemlins/confused.gif
   / Stiff 3PT Lift Arm Sockets? #8
Mayhem,
Mine were new and stiff too. I got mine loose by spraying a ton of wd40 then inserting one end of a strong, long metal rod. A contractors stake that holds carpenter string works great. Hold one end of the rod (3ft or more) and move in a figure 8 pattern. They loosen up quick. The paint comes off with the friction and the WD40. Of course the balls / arms must be secured to something. I used this with other implement / ball attachements including the hydralic cylinder balls with great success.
   / Stiff 3PT Lift Arm Sockets? #9
sent you a PM
   / Stiff 3PT Lift Arm Sockets? #10
Mayhem, mine were very stiff to the point I could barely shift them with a loose cat2 pin. Somebody suggested PB Blaster and it sure has worked well for me. So well in fact that now when I put my cat 1 bushings in to hook up smaller implements I have a tough time keeping them from rotating and dropping my freshly cleaned ready to go bushings in the dirt. /forums/images/graemlins/frown.gif /forums/images/graemlins/grin.gif
Steve
Honda EM7000iS 7000 Watt Inverter Generator (A50322)
Honda EM7000iS...
2014 John Deere 652R (A50121)
2014 John Deere...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
2015 JLG 6042 Telehandler (RIDE AND DRIVE) (A50774)
2015 JLG 6042...
Skidloader Forks (A50774)
Skidloader Forks...
