Stihl 029 clutch replacement
   / Stihl 029 clutch replacement #1
mike0000
Platinum Member
Southern Indiana
Kubota RTV 900, Kubota L3901, Kymron YH 14 mini ex
Looking for some direction, I need to replace the clutch (under drive sprocket) on my old 029, it’s close to thirty years old. My attempts to break it free have not worked so far, it is really stuck. Is it a bad idea to remove the spark plug and insert some rope to lock the crankshaft in place? I’m concerned I could damage the rod or piston trying this. It’s currently soaking w/ acetone/transmission fluid. Thanks for any recommendations.
Mike
Scratch that, I just hit it with the impact driver after the acetone transmission fluid soak and it broke free!
Mike
   / Stihl 029 clutch replacement #3
Our local Rural King has a full time Stihl rep there in the Saw section. He can get parts.
   / Stihl 029 clutch replacement #4
Thanks, I’m headed to our RK in the morning in search of parts, hopefully they can help me out.
Mike
   / Stihl 029 clutch replacement #7
I use the rope method most of the time. The stops can get broken off inside the cylinder if they don't fit right. I compress the piston against the rope or stop and loosen the clutch with an air impact set on low. Works fine.
   / Stihl 029 clutch replacement #8
I've used a rope as a piston stop on an 029 (and many others) many times. Then I bought the plastic piston stop and have yet to use it in the 10+ years.
   / Stihl 029 clutch replacement #9
Depends on your RK for parts. One north of me sells stihl and one south of me husqvarna.
I ended up stopping by a local store (PC Lumber) they sell and service Stihl saws. They had the parts I needed.
I borrowed my brothers new Stihl MS 261C while my 029 was down. I was amazed at the difference in power, I decided to pick one up for myself. I went with the same bar length so chains will work for both saws.
Mike
2010 KENWORTH T660 TANDEM AXLE MID ROOF SLEEPER (A56138)
2010 KENWORTH T660...
2007 FREIGHTLINER COLUMBIA 120 (A55745)
2007 FREIGHTLINER...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2012 BOBCAT E80 EXCAVATOR (A52707)
2012 BOBCAT E80...
