Stihl brushcutter grease
   / Stihl brushcutter grease #11
How do you know if you need more grease? When I remove the plug and look into the gearcase I can see the drive gear, it looks like there is some grease on the teeth but there doesn't appear to be any extra grease surrounding it.
Do I need to put more grease in?
   / Stihl brushcutter grease #12
I'm sure no expert, but if I could see the gears instead of just grease, I'd be adding some grease. Someone else might think differently though.
   / Stihl brushcutter grease #13
Thanks Bird
I think I'll pick up a tube of grease.
   / Stihl brushcutter grease #14
I picked up a tube a couple of years ago, never did add any. My FS130 is about 6 years old, I probably should check it..;)
Sean
Well since this thread has gone far beyond me capitulating to the "Stihl Grease or Die" what about this scenario:
Saturday at noon - need to brush cut, check the cutter it's low on grease. No dealers open till MONDAY. Don't cut or put in a substitute?
   / Stihl brushcutter grease #16
When I was repairing/rebuilding mechanics' air tools, the different air tool manufacturers recommended specific grease and/or oil for the different tools, but as I always said, ANY oil & grease is better than NO oil & grease.;):laughing: Maybe in your case it depends on "how low"?:D
   / Stihl brushcutter grease #17
I check mine once in the spring. I fill it to the bottom of the bolt hole and no fuller. Mine seems to need a little grease every two years.
   / Stihl brushcutter grease #18
I guess maybe I should look over the manual again (if I can still find it)...I didn't realize these things could even BE greased!
BOB
   / Stihl brushcutter grease #19
I'll do it next time.
Well, my FS90R is 6 years old and next time finally came around thanks to this thread reminding me. I could see plenty of grease on the gears but I added some anyway.
It should be good until next time.
:eek:
BOB
One of the nice things about Stihl is that most of their manuals are on line.
/edit - and I picked up a tube of grease. It better last long!!
2010 Chevrolet Tahoe SUV (A53424)
2010 Chevrolet...
2016 FREIGHTLINER CASCADIA (A53843)
2016 FREIGHTLINER...
Electric Mobility Scooter (A51694)
Electric Mobility...
2016 Ford SD Dump Truck (A52377)
2016 Ford SD Dump...
2023 G Bar K Goose Neck Flat Bed (A55218)
2023 G Bar K Goose...
KUBOTA M6800 UTILITY SPECIAL TRACTOR (A51406)
KUBOTA M6800...
