jinman
Rest in Peace
- Joined
- Feb 23, 2001
- Messages
- 20,387
- Location
- Texas - Wise County - Sunset
- Tractor
- NHTC45D, NH LB75B, Ford Jubilee
Hey, Jim thanks for the reply, I did check and replace the fuse you said (and the other ones as well) no luck. When you turn the key on. the normal lights come on plus the PTO light. Then after about 15 sec there is a relay in the fuse block that clicks and the lights flash a sec then on steady then repeat.
I am willing to try anything you suggest.
Robert
Sometimes the fuse #2 will continue to blow. A 10 amp fuse could be blowing. I've blown several 10 amp fuses. You might try a 15 amp, but don't go more because of possible wire damage. A self-resetting CB that directly replaces the fuse is the best bet. I have a 15 amp self-resetting CB in my tractor and it has performed flawlessly. Whatever you do, don't jumper across the fuse. That's a sure way to burn up a bunch of wires.
If you continue to blow the fuse, walk around to the right side of the engine where you can see the injector pump (raise the hood). On the back side of the injector pump is a round solenoid about 1" in diameter and 3" long. This is your fuel cutoff solenoid and is on the fuse #2 circuit. Pull the connection to the spade connector on the back of the solenoid and see if the fuse stops blowing. I think the clicking and blinking you are hearing is the glowplug relay cycling. If you turn on the key and the PTO light is on, you DO have a blown fuse #2 if the PTO lever is off and you didn't get something shorted at the switch when you were checking it.
BTW: Fuel cutoff solenoid problems are pretty rare, but I had one short out on my tractor and had to be replaced at $125. It does happen.
Good luck!
