Stinky Water Well
   / Stinky Water Well #11
If you are not living in the house yet, you can put 5 pounds of chlorine powder into the well and that will oxidize the sulfur and should eliminate the problem for a while. Other than that you will have to learn to live with it. This is what I did with our well and that was 20 years ago. Now no visible rust or sulfur smell.....
   / Stinky Water Well #12
They make a device that sits on your wellhead and drops a pellet of chlorine in your well every so often. Nobody has suggested a water softener. Don't they work for sulphur?
   / Stinky Water Well #13
This is from experience:
1. Have your water tested. Often sulphur water contains iron and other metals. If you are serious about rectifying the problem, you need to know exactly what you are dealing with as far as the water properties of your individual well. Armed with this information, you can avoid wasting serious money on a supposed solution that does not address all of your well's issues.
2. "Sulphur water" is usually the result of one or two conditions: sulphuric bacteria or sulphuric particles - or both.
The bacteria scenario can be solved with an aeration or reverse osmosis device. You can easily find information on the net for the FAQs of these implementations.
The sulphuric partical solution requires a different tract. (This is the situation I've had to deal with BTW). This requires a chlorination solution. In my situation, I purchased and had installed a CL2 system. Basically, it consists of a holding tank (120 gallons), a solution tank (35 gallons) with an injection pump and flow switch, and a carbon filter tank. Follow along: a: Water arrives in the holding tank directly from the well. b: The solution tank injector introduces a diluted chlorine solution into the water flow. This destroys the sulphur content. c: This chlorinated water now passes through the carbon filter, (whose job is to remove the chlorine which is carcinogenic and linked to certain cancers in humans, they would have us believe) and out to your various plumbing services.
I'm told that either form of sulphur can also shorten the length of copper fixtures as a result of scaling in the pipes.
PROS: It works, guaranteed. I test my tap water with a pool test kit to make sure the carbon filter tank is doing its job.
CONS: The CL2 systems are somewhat expensive (1800 to 2500 USD, installed); require manual maintenance (flushing, 35 ga. chlorine/water tank requires 3 ga. of bleach to 32 ga. of water and must be done by you. The holding tank must be flushed manually. The accumulation of empty Chlorox bottles is becoming a problem (HELP!).
The carbon tank's useful shelf-life is finite. Depending on your water's exact properties, I guess anywhere from 2 to 5 years, it will need to be replaced (apprx. 200 USD).
Obviously, the CONS tips the scales, however, the sulphur in our water was at a VERY high level. Bathing, drinking and otherwise general use of this water was OUT for my family. Strangely, our well was probably dug in 1938 and our 220 yo. home was often referred to as "Stinkwater Holla". We are the first family to do ANYTHING about the sulphur problem.
IMHO, introducing chlorine or bleach DIRECTLY into the well is NOT A GOOD IDEA unless you know for sure that your well has been contaiminated from an outside source. Chlorine will kill the good or harmless stuff in the well, like bacteria that eats other bacteria for instance, resulting in what's termed "dead water".
Hope this helps.
<font color="red">DISCLAIMER:</font> I'm not a chemical biologist, nor did I stay at a Holiday Inn last night, just my experiences dealing with Stinkwater Holla and the vendor who provided my solution.
If ya want more exacting information on my CL2 situation, drop me a line.
Hope this helps. /forums/images/graemlins/grin.gif
   / Stinky Water Well #14
</font><font color="blue" class="small">( The accumulation of empty Chlorox bottles is becoming a problem (HELP!). )</font>
Get some swimming pool chlorine powder and mix 3 or 4 tablespoons of it with water and reuse the Chlorox bottles. Much less expensive and just as good as buying it in the store. I did this for years in my shop where we would go through 2 or 3 gallons a day during a maintenance sweep..
   / Stinky Water Well #15
J ... thats a superb idea ... pool shock ... an extra trip, but I thought for sure I'd come up with a use for all that plastic. I was wrong. Now I just have to figure out how much to use per jug.
One thing's for sure .. my home will never sink!
/forums/images/graemlins/tongue.gif
   / Stinky Water Well #16
<font color="blue">the chlorine which is carcinogenic and linked to certain cancers in humans, they would have us believe </font>
EEEP! And I've been around so much chlorine, you'd think I've been swimming in it! /forums/images/graemlins/wink.gif
   / Stinky Water Well #17
Ranchman:
The nasty stuff refered to is the result of a chemical reaction with organic materials in the water. I beleive it's called THP levels but don't ask me what the letters stand for. Municipal water suppliers monitor the levels.
Think the water has to be ingested.
For the really curious a quick web search should find all kinds of information.
Egon
   / Stinky Water Well #18
<font color="blue"> has a really bad sulphur smell and taste, especially when it's heated in the water heater. </font>
Charlie
It's been a while since you started this tread. But this may be of some help to you and others.
I few weeks ago I needed to replace a 5 year old water heater. /forums/images/graemlins/frown.gif
The old heater had the rotten egg smell since I bought the heater at Home Depot.
/forums/images/graemlins/mad.gif
I figured that the new heater would have the same problem. /forums/images/graemlins/frown.gif
I read through the manual and found that they recommended changing the anode rod. When I went to the Rheems site they had a FAQ section on rotten egg smell.
What I found was that how hot the water is heated will increase the amount of gases that are released.
I lowered the water temperature to 110 degrees.
I have not had a bit of smell since lowering the temperature. /forums/images/graemlins/cool.gif
Here are the 2 links on Rheem’s site. Hope it helps with the smell you and others are getting.
Click Here
Click Here
   / Stinky Water Well #19
Charlie,
Up here in NH I had a similar situation with the water "rotten egg smell" which got worse with adding heat to the water. I had a full analysis of the water done and found it to be fairly decent PH and iron wise. The Hydrogen sulfied smell will come back a few weeks after chlorinating, if the problem is indeed hydrogen sulfied. A good well pump company will come out for free (at least up here) and tell you what you need. I installed an aerator at my house which took care of the odor completely. The unit cuts into the piping before the storage/bladder tank. There is an adjustable ("micronizer") valve which introduces air into the water line before it passes thru the actual aerator. Somehow in the aerator the air introduced into the water combines with the hydrogen sulfied gas and it is separated and ejected outdors via a plastic tube. The unit ran $750.00 cash and carry. It did the trick.
Good luck,
Peter
   / Stinky Water Well #20
I'm an engineer with a water purification company.
The problem is simple to correct, with a proper chlorinator.
DO NOT DUMP CHLORINE in the well or tank as some people suggest, as sodim hypochlorite (chlorine) is an oxidizing agent, and can damage pumps, and components, and will not have sufficient contact time to do much good anyway. What you need is a chlorinator that drips chlorine into a new tank.
That will also kill most (but not all) bacteria that you might find in the water. Then I suggest running that water through a simple carbon tank, which will remove the chlorine.
It's not complex, and it's not really expensive. You should be looking at about a grand for the chlorinator and carbon tank. I would suggest however that you go for the largest carbon tank and valve possible (usually about the size of a large scuba tank) so as to minimize the drop in pressure.
You will have to replace the carbon periodically (probably every couple of years and it's cheap) and you will have to add chlorine bleach, the kind you buy in a grocery store periodically.
Check out the website for the Water Quality Association and it'll answer all sorts of questions.
good luck,
Anthony,
Century 3647 on 12 acres
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2023 G Bar K Goose Neck Flat Bed (A55218)
2023 G Bar K Goose...
2011 New Holland Boomer 90 MFWD Utility Tractor (A55301)
2011 New Holland...
2010 Chevrolet Tahoe SUV (A52377)
2010 Chevrolet...
2007 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XL...
2014 CATERPILLAR 289D SKID STEER (A52706)
2014 CATERPILLAR...
