TheMan419
Veteran Member
So we have horses. 100 gallon rubber maid stock tank. We had an outlet installed by an actual electrician to run the deicer. It is a 3 prong GFCI outlet. On its own circuit.
Wife is concerned that she is reading stories on the internet of horses getting electrocuted because the deicer was not grounded. They are recommending a ground rod. Attach wire to ground rod and place wire into tank. Weight it down with a brick so it is always in the water.
Isn't the GFCI supposed to handle things? If I plug a toaster into that outlet, turn on the toaster and toss it in the stock tank the GFCI would trip right?
According to the multi-meter the GFCI is functioning properly.
Am I missing anything other than "Just do it because SWMBO will hound you until it is done"?
