Stopped that noisy rod
   / Stopped that noisy rod #1
blueone
Eastern Panhandle WV
KOBOTA L3540
I have had my 3540 for 6 months and since new the bucket level indicator rod on the LA724 FEL was always noisy and bugged me. Yesterday I had the old light bulb come on. Had some poly tubing laying around so I found a piece that was 3/8 ID, sprayed a little oil in and it slid right on the rod. In short here's what i did.
1] mark and remove rod
2] ream out the guide bracket and deburr
3] slide the poly tubing over the rod and 3" past mark
4] reinstall rod trough guide and into connecting tube, tubing will go into tube but it's tight. if to tight sand down to fit
I also added a lock collar just cause i had it but if the poly tubing is 3" inside the connecting tube it probably not necessary.
So far there is NO more screeching!!!!:thumbsup:
2026 tilt trailer (A56859)
2026 tilt trailer...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
2010 Dodge Ram 4x4 Crew Cab Pickup Truck (A59230)
2010 Dodge Ram 4x4...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
