Strange dead spots in pasture. Can you guess the cause? (SEE PICTURES)
   / Strange dead spots in pasture. Can you guess the cause? (SEE PICTURES) #11
From the overhead picture I would say that it is drainage. Sometimes fields are left without cover and the topsoil washes away. Different plants grow in different types of soil.
   / Strange dead spots in pasture. Can you guess the cause? (SEE PICTURES) #12
Is irrigation required there in the summer? Maybe it got too dry and died.
   / Strange dead spots in pasture. Can you guess the cause? (SEE PICTURES) #14
Mixing in a product called Biochar will likely help absorb any toxins in the soil causing the problem. It woudl work best if you have a box blade with rippers so you could work the biochar into the soil. Let that sit for a few rains and then hit it with some compost before reseeding.
   / Strange dead spots in pasture. Can you guess the cause? (SEE PICTURES) #15
Definitely looks like standing water damage due to poor drainage. Look for a way to let the water drain off quickly and I think your problem will go away. There could be some chemicals on the run off that also complicate the issue but the easy fix will be to let the run-off water drain off and then you wont have concentration of chemicals or fertilizer standing on the low spots. This type of damage is not unusual in low spots.
   / Strange dead spots in pasture. Can you guess the cause? (SEE PICTURES) #17
OP, I agree with Gary Fowler that it looks like standing water damage. You did ask us to guess, and I would think that like me, Gary has made an informed guess because he has seen it before.
Guessing again, I very much doubt it is salt (very extremely unlikely) or chemicals (extremely unlikely because it would not persist). When did you first see the land and has the situation changed since then? Do not spend any money until you are certain you know the cause.
   / Strange dead spots in pasture. Can you guess the cause? (SEE PICTURES) #18
If it turns out to be from water holding in those areas, I would try running a subsoiler as deep as it will go about 3 ft apart over the affected area. In lots of cases, this helps or completely fixes the problem. Ken Sweet
   / Strange dead spots in pasture. Can you guess the cause? (SEE PICTURES) #19
We had a situation like this and our old farmer friend ran a shallow plow down the middle to make a ditch. Less than a foot wide and deep but it collects all the standing water in the immediate area. So you sacrifice a very small bit of land but it is an inexpensive way of rejuvenating a lot more of the field.
Thanks all for the guesses/advice. I'm going to take some soil samples this Summer, which would confirm or rule out the salt issue. If the damage was due to runoff, it must have happened before I purchased the property a year ago. I'll keep an eye on things during the spring rains and see if there are elevation problems. Then I can subsoil, if needed to get rid of standing water. I'll post back here with the correct cause...once I confirm. Thanks again!
MAHINDRA 6110 TRACTOR (A51247)
MAHINDRA 6110...
2012 Bomag BC572 Refuse Compactor (A51691)
2012 Bomag BC572...
2019 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
