Strange Noise in front end of Max 22
   / Strange Noise in front end of Max 22
That was it! So is the an ongoing problem Charlie? Seems like tightening of the bolts and some loktite should do the trick, no??
   / Strange Noise in front end of Max 22 #12
I put the camera there to try and find the noise and had thus taken off the drive shaft to inspect it. Put it back together and then no noise. Looked closer at the cover but due to the absence of any rub marks I was dumbfounded but what the noise was. I guess it is the drive shaft moving around at that speed causing the cover to rattle. It's been quiet now for a week!
I have 100 hours on mine and it just happened when I made the post, so I am guessing it is not much of a big deal. I seldom drive in high gear, which is the only time I heard it rattle so maybe it was that way for a while. Anyway, it is an easy fix. Thanks for the video, that was pretty cool.
   / Strange Noise in front end of Max 22 #14
Same issue here at about 60 hours on my 2012 Max 25. A buddy found it while we were loading tractor and was a simple fix.LOCTITE. As the manual states check all bolts and nuts after so many hours. Still I can't
complain after what I put it though. One tough tractor.
   / Strange Noise in front end of Max 22 #15
This old thread and TBN got me going again on my post Dorian cleanup. This tractor newbie heard this awful racket that sounded like the front axle disintegrating and had visions of spending BOAT unit$ (for non-boaters that means Break Out Another Thou$and). Quick search on TBN and a 5 minute fix! Hopefully I'll be able to pay it forward one day...
Thanks everyone!
Rip
   / Strange Noise in front end of Max 22 #17
Exactly, tightened the bolt (will add Loctite when I can get to it in my shop) on the metal cover over the front end of the front axle drive shaft and racket disappeared. Finding this possible answer allowed me a good night's sleep (hard to come by before, during and after hurricanes) and after breakfast the next a.m. I fixed it in 5 minutes and off to the edge of the swamp to retrieve our 120 gallon propane tank so we can cook and have hot water...
   / Strange Noise in front end of Max 22 #18
Having a front loader really comes in handy especially after a storm. Hope no more problems. Good luck
2003 Lincoln LS Sedan (A50324)
2003 Lincoln LS...
2014 MACK CHU TANDEM AXLE DAY CAB (A51219)
2014 MACK CHU...
2018 John Deere R4038 Self Propelled Sprayer (A50657)
2018 John Deere...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
1999 MACK CH613 WATER TRUCK (A50854)
1999 MACK CH613...
(INOP) CATERPILLAR TL943 TELESCOPIC FORKLIFT (A50459)
(INOP) CATERPILLAR...
