Stuck exhaust valve??
   / Stuck exhaust valve?? #1
justletmefish
Poteet, TX
I have a JD790 and when I started it the other day it made a pop that sounded like an air hose burst and when it started it sounded like an exhaust vale was stuck open. Anyone had anything like this happen to them??
   / Stuck exhaust valve?? #2
I assume your 790 is out of warrantee? You could pull the valve cover and see if a valve is stuck open.
BTW, I also have a 790 and grew up very close to Poteet (between SA and Castroville). Good luck.
thats what I'm goin to do. only has 100 hrs on it but its still out of warranty.
thanks
   / Stuck exhaust valve?? #4
Hiya,
Hmmmmm, most Diesels have very little if any clearance for a valve that sticks open and you would defenetly hear a piston wacking a valve that stuck open. (In reality, the piston would unstick the valve very quickly but would most likely bend the stem.)
What may be more likely is that you spit out either the glow plug if equiped or the injector. Pop the hood and take a look for those first before you yank the cover, may save you a lot of work.
My 2 cents,
Tom
   / Stuck exhaust valve?? #5
No glow plugs on the 790 but an injector blowing out is a good thought. I've had a similiar sound when I blew a spark plug out on a gas engine.
UNUSED RAYTREE RMDM72 - 72" HYD DRUM MULCHER (A54757)
UNUSED RAYTREE...
UNUSED (2) 7000# DROP AXLES W/ BRAKES (A54756)
UNUSED (2) 7000#...
New Hay Saver Horse Round Bale Feeder (A50775)
New Hay Saver...
Toro Workman HDX-D Utility Cart (A53421)
Toro Workman HDX-D...
2008 CATERPILLAR 330DL EXCAVATOR (A52705)
2008 CATERPILLAR...
Utility Trailer (A52377)
Utility Trailer...
