stuck front axle Fill Plug on Deere 2955
   / stuck front axle Fill Plug on Deere 2955 #1
gtrgarden1
What ideas do you have for loosening the Fill Plug on the front axle of a Deere 2955 tractor?
The plug is not stripped. A breaker bar fits tight in the plug, but no amount of heaving I have done is breaking the plug loose.
I sprayed some WD-40 around the plug yesterday to see if it might penetrate to help loosen the thread [I haven't checked back on that yet]. But, since the plug is on the side of the axle, I'm not sure if any penetrant would have much opportunity to move down into the threads.
I suppose heat would also be an option.
   / stuck front axle Fill Plug on Deere 2955 #2
I don't know how much work space you have but sometimes an impact wrench can loosen frozen threads. Sometimes you can break a frozen fastener by tightening before loosening but I don't think that would work well with a tapered thread plug.
   / stuck front axle Fill Plug on Deere 2955 #3
Have you attempted to hit plug with a large hammer? If large hammer doesn't loosen plug my next choice would be an acetylene torch.
   / stuck front axle Fill Plug on Deere 2955 #4
Saw this on another forum:
Doug in SW IA
   / stuck front axle Fill Plug on Deere 2955 #5
I was going to recommend the same exact thing. Impact wrench. Try tightening. Sometimes that breaks away from something holding it from turning in the reverse/out direction.
I think I would drill it out before resorting to a torch. If you drill put grease on the drill to collect chips and clean and regrease often. Good luck!
   / stuck front axle Fill Plug on Deere 2955 #6
impact. tighten then loosen.
   / stuck front axle Fill Plug on Deere 2955 #7
Wd-40 is about worthless for a penitrant. Hit it with a hammer a few times, the shock should loosen it up. If not you may need to heat it a bit.
2006 Nissan Xterra 4x4 SUV (A51694)
2006 Nissan Xterra...
(INOP) 1994 HONDA 200 ATV (A51247)
(INOP) 1994 HONDA...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
John Deere BD1108 (A50123)
John Deere BD1108...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
2015 Linde H35D 4,350lbs. Diesel Forklift (A51691)
2015 Linde H35D...
