Stuck in the mud
   / Stuck in the mud #11
johnk said:
I think a lttle rear end weight and it would have walked right out. You just wanted a reason to use the dozer. Then you tell everyone what a tough day you had with a big smile on your face. Two toys in 1 day,,,, " PRICELESS"
Looks like with somebody on the tractor the car would have pulled it out.
   / Stuck in the mud #12
MadReferee said:
Here are some pictures of me using the dozer to get him unstuck.
sounds like you had fun day, and looks like a really nice DOZER, nice to have your own reteiver, and is that a Black walnut tree i saw in the forground?
   / Stuck in the mud #13
ttowne66 said:
Mad
Looks like there was no effort to use the FEL. I believe that would have got this out.
You are right, FEL would have worked.
Bob
   / Stuck in the mud
As I said earlier, the pictures of the mud hole are really deceptive. There is no hard ground there to use with the FEL. What you are seeing is mud with standing water covered with leaves and branches. However, we didn't try using the FEL because my son didn't want to dump the load of logs and because it's easier to get the tractor out using the right tool (the dozer). I don't think it (using the FEL) would have worked anyway.
The tree is not a walnut, it's a chinese elm.
   / Stuck in the mud #15
Having a dozer is nice!!!!!!!!!!!!
Bob
   / Stuck in the mud #16
The picture has become a little clearer now. No weight on the back and not dumping the load in front. When I've gotten stuck like that the BB or BH was on and had to dump the load out of the bucket or forget it. Would really like to have a little dozer like that as well.
   / Stuck in the mud #17
I don't know a whole lot about New Hampshire, but I do know this, you have MUD!
And, yes, nice dozer! Right now I wish I had that to remove the rest of my barn. May be renting one soon.
   / Stuck in the mud #18
I know I'm just a mean guy but I would have made the kid dump the logs and try to back out with alittle help from the fel. He would think about not getting stuck next time after picking the logs out of the mud. :D
   / Stuck in the mud #19
Wow, that is one good looking Dozer. I wish I could get a few hours in on that. :D
I've been to Mad's house several times, the pictures don't do justice to how wet that area of his property is. That said, why fight the Kubota when that TD6 would snap it out of there in 10 seconds.
   / Stuck in the mud #20
Excellent point,I would have done the same thing if I had a dozer.
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53473)
Ditch Witch 6510A...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2017 Mitsubishi Fuso 16FT Box Truck (A51692)
2017 Mitsubishi...
2005 Freightliner M2 106 Dumpster Carrier Truck (A51692)
2005 Freightliner...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A54607)
2015 UTILITY VS2RS...
Peterbilt National Crane Series 900A 26 Ton Tri-axle Crane Truck (A52377)
Peterbilt National...
