Stuck PTO: can't get it to engage in top 2 speeds
   / Stuck PTO: can't get it to engage in top 2 speeds #1
tractorgreenie
Germantown, TN
Belarus 250AS, Massey Ferguson 20C
Looking at a used Iseki TS1610.
The PTO lever has four speeds.
1 and 2 are on the left, then you push across the middle divider and 3 and 4 are on the right.
I couldn't get it into 3 or 4 b/c the outside of the shifter was rusted.
Sprayed PB Blaster on it and then was able to force it into 3rd--not meaning the gear was hard to engage, but the exterior rust was hard to work against.
Let out the clutch slowly and the engine acted really loaded and started to cut out.
PTO splines didn't move at all. Not "they moved slowly"...they didn't turn a bit.
Is it likely just gunked up, or does that necessarily mean that the gears in the transaxle for the PTO are seized (by rust, etc.)?
I didn't even try to get it into 4 b/c I had to use a hammer to tap it out of 3 and obviously couldn't move the tractor if the PTO got stuck engaged but I couldn't get the lever out...
Thoughts?
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56438)
2012 MACK Tender...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
