Stuck Tractor
   / Stuck Tractor #21
Thats a good point if he was trying to pull himself forward and pushed the lever all the way to the right into regen, then of course he would have no power... what say you Original Poster? were you trying to push yourself backwards by curling? or trying to pull yourself forward? (doesn't work too well in any case)
James K0UA
On my 3940 you must push past the detent to get power, it is regen first as you go to the right. In other words it is made for easy and quick loader dumping.
On my blower chute rotator you must go past regen or the motor will not run either.
   / Stuck Tractor #22
That's interesting as my old standard L series had regen on the far right as does my current Kioti.. In any case I never had any luck trying to pull myself forward, I have been able to push my self backward many times to get unstuck.
James K0UA
   / Stuck Tractor #23
James K0UA
I agree that back seem to work much better. In my old age I have learned to leave the tractor parked when it is wet!!!!:thumbsup:
   / Stuck Tractor #24
James K0UA
I guess I am going to ask a dumb question but what is a regen?
   / Stuck Tractor #26
Can't offer any more advise (uh,, good advise) than hasn't already been mentioned. I sure don't intend to make lite of your situation but back in our drinking days we'd rate each time someone got stuck in how many six packs it would take to get ur out. Getting stuck around here was a good excuse for a community get together. Most jobs were a few six packs except when my uncle stuck his D8 in a drainage ditch he was attempting to clear out. It took a lot of cases as it rained that night and the next morning the Cat was serving as a dam. Water was almost to the seat.:eek: What a muddy mess after the water receded.
Good luck to you
   / Stuck Tractor #27
I probably cannot explain it very well but until someone comes on that really can explain it I will give it a shot. here is the setup, you have a heavy load in the bucket, and you go to dump it by pushing the stick to the right (at least on my joystick control) and this powers down the load with the fluid from the pump filling the cap end of the cylinder as fast as it can, However the load itself wants to go down faster due to gravity on the heavy load. The pump cannot provide fluid at the rate needed to fill the cylinder and a void develops in the cylinder. now remember when you are filling the cap end of the cylinder fluid is being pushed out of the rod end of the cylinder back to tank. Well there is a further over to the right (at least on my valve) past a detent that is called regeneration. This position takes some of that fluid that would be going to the tank and puts it in with the fluid coming from the pump to fill the cap end faster to prevent the void from forming in the cap end, and this allows gravity to pull the bucket into a dump position faster. I probably did not explain this very well, but the idea is that regen position will allow a faster dump of a loaded bucket.
James K0UA
   / Stuck Tractor #28
James K0UA
Thanks for explaining that. I never noticed it on my bobcat or read about it in the manual. I will have to check and see if the L4240 has it.
   / Stuck Tractor #29
James K0UA
   / Stuck Tractor
Thanks for all the replies to my question. Learned a couple of things from the advice offered. Learned what regen is and how it works. I just need to get out and practice my technique. Last time I got stuck had to get a dozer in to pull me out. Thank God for friends.
2015 Ford F550 Service Truck (A52377)
2015 Ford F550...
54in Fork Attachment (A55851)
54in Fork...
7033 (A51691)
7033 (A51691)
2016 Cat TL1055D Telehandler (A55314)
2016 Cat TL1055D...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2016 Chevrolet Silverado 2500 HD 4x4 Pickup Truck (A55973)
2016 Chevrolet...
