Stump removal....the fire way
   / Stump removal....the fire way #11
One way to burn them out is to use a truck or tractor rim around the stump to contain the fire. Keep a good fire going & it will take them right out.
RONE
   / Stump removal....the fire way #12
The problem with burning stumps is the roots pull water from the ground. It creates steam, and that prevents a good hot bed of coals from forming.
The best time to burn them is during a long dry spell.
I have found that diesel actually cools a fire down. Big dense wood is a much better solution, as someone already mentioned.
The best way I have found to burn a stump is to use Green Light stump remover (99% saltpetre). Apply it per instructions. Dig around the stump, exposing as much roots as you have the energy for. Wait for a very dry spell, then pile big wood on and around the stump. No diesel needed, just burn it.
Tip: If you have a large shop fan or leaf blower, they can make a VERY HOT fire. :)
   / Stump removal....the fire way #13
Then there is the 'cover and forget' method. Dig down and cut it off below ground level and backfill over it. Eventually it will rot out and you will have to add some dirt to fill the, now collapsed, hole. I have one big one (4' across) Red fir that is under a flower bed off the back porch. Every spring when I spade it, I bring up some rotten wood.
Harry K
   / Stump removal....the fire way #14
I have had good luck burning stumps if you cut the stump off close to the ground. Than take 4-5 piece of fire wood and pile on top of it and get it burning. Than take a old piece of tin and place over the fire. The tin acts a heat shield to keep the heat in on the stump and the stump will burn for days. It also will keep the rain out from cooling down the fire. I usually just throw a Cinder block on top of the tin to keep it from blowing away. I burnt a 30" red oak tree 30' long that had fell like this once that was to big for my saw to cut through. I just lite it on 1 end and got the fire going than laid the tin length ways on the trunk. Than every day I would go out there and slide the tin down the trunk. It took about 30-40 day and the tree trunk was gone.:)
   / Stump removal....the fire way #15
Great idea Tim. I'll have to try that.
After worrying with my last 2 burning stumps, I swore I would never leave one again. Next time I will saw the stump and roots flush or below the ground. It's hard on the bar and chain, but a new bar and chain cost less than 30 dollars. That's way less than you would pay for someone to grind it, plus you get a new bar and chain out of the deal.
   / Stump removal....the fire way #16
My neighbour digs around the stump, then pressure washes it before he'd touch it with a saw. ;)
I had good results by digging free some roots, use an axe to cut some roots halfway, rip off some main roots with a chain before pushing over the whole tree.
   / Stump removal....the fire way #17
Renze,
I agree, the best stump removal method has a tree attached for leverage. I dig around the base looking for the 3 main roots. With a saw or axe, cut out a 6" section of the roots. This allows for the whole tree to piviot with out compressing on the remaining root. Put a cable around the trunk at 12'-15' up via a ladder. Pull her down. most trees up to 10" dia come over root ball and all.
   / Stump removal....the fire way #18
I have trees that are very close to underground gas, electrical, phone and septic system. It's also possible to have have oil, gas, water and electrical underground utilities that cross your property either as mains or as services to neighboring properties. By the sounds of some peoples success at burning the roots many feet from the stump I would hope that anybody trying this would make darn sure they were a long way from underground utilities.
   / Stump removal....the fire way #19
Paddy said:
Renze,
Definitely a nice way to use physics to your advantage. But don't do something like I did.
One day 2 years ago, later in an afternoon of felling 4 or 5 Pinebark Beetle infected trees, I got to one that needed to come down in a specific direction. We sawed it so that it did not immediately fall, but was waiting for a directional tug.
I put a rope about 10' up, tied the end of the rope to a strategically-placed stump, attached all to a comealong, and began cranking.
Crank crank crank. Then suddenly a loud and shaky voice calls 'Run Mr. Petersen ... run for your life!!!' Sure enough, here comes the big Pine tree heading down right in my direction. I scooted aside and one of the branches just brushed against my elbow - exactly like a close-call scene from a highly dramatic movie.
But life isn't a movie, and dumb things like this can easily turn into tragedy. I finally learned after a couple such episodes that fatigue and rushing through a long day has no place in the country. Loved ones need you home every night much more than they need a Pine tree in a horzontal position.
Very well said Slobud. I spend a lot of time by myself at my farm. We don't live there fulltime and I enjoy spending a day or two alone just working on different projects. I have had a couple of mishaps that could have been a lot worse. I fell off a ladder and broke four ribs. Had I hit my head instead of ribs........well you get the picture. I have to constantly tell myself to be careful. A project left undone until help is around is OK. Projects can wait.
Ok now back to the subject I originally posted about. I burned two stumps this past weekend. Old seasoned maple if verrrrry hard and doesn't burn as readily as I would have imagined. I did make a lot of progress, but there is still a bit of wood above ground. I'll fire it up again next weekend and hopefully finish that project. When that one is finished, I'll have only about 99 more to start. It's funny how work has become my recreation. Oh well, life has lots of twists and turns.
2005 GMC Sierra Pickup Truck, VIN # 2GTEK13T851399344 (A54865)
2005 GMC Sierra...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
1997 CATERPILLAR 322BL EXCAVATOR (A52707)
1997 CATERPILLAR...
FIFTH WHEEL MOUNT (A55745)
FIFTH WHEEL MOUNT...
