Stump removal
/ Stump removal #1
mollysmaster
Upstate New York
Kubota B7610
After two days trying to remove a large (30-35") stump with a Kubota 7610,fel, shovel, and axe, I finally came to my senses and will farm out the job. I have about 25 other stumps to remove. My question is does anyone have an idea what the cost will be to hire someone with a bulldozer? to remove the 25 or so stumps? This is in the Saratoga Springs area of New York.
/ Stump removal #2
A dozer is the last thing I'd bring in for stump removal. An excavator or trackhoe would be my first choice, especiall with big stumps and plenty of them. If the price for one of them is too much, get a backhoe in there.
I'd want a trackhoe of at least 100 hp and prefer something closer to 150 hp or more to get it done quickly.
A dozer will spend too much time moving more dirt than you need to move, and unless its a big dozer, it might not even be able to move very much dirt when it gets through the top soil. Depending on your conditions, what's under the topsoil could be extremely hard and very difficult to cut with the blade of a dozer. My dozer weighs over 40,000 pounds and has 168 hp and I park it before wasting time and energy on stumps.
I have a Ford 555E backhoe that I use on stumps and big trees. It's ten times faster and easier to use, than my dozer for takeing them out. Especially the big pines and oaks.
Good luck,
Eddie
/ Stump removal #3
I can not speak directly on your area, but here in Pennsylvania, I had 28 stumps removed from my property all in a heavy clay soil. I shoped around and got prices by the hour from 25 - 100 dollars.. I went with the 25 dollar per hour person and he was done in 4.5 hours.. He used a large JD backhoe and for the money he also knocked the clay-dirt off the bottom and relocated the stumps for me.
Shop around. Most construction companies should be able to give you a quick estimate.
/ Stump removal #4
Not sure WHERE the stumps are at and if they NEED to be REMOVED or just ground up.. you can have them ground up for pretty cheap, depending on how far the grinder guy has to go and if he is in the area and if there is enough work ect... Just thought I'd suggest that as many people may not know that you can grind a stump into the dirt and do very little damage to surrounding area.
MarkM
/ Stump removal #5
$25 per hour for a big machine and an operator is dirt cheap. You were fortunate to find someone who, to me, didn't know what his time was worth or what his machine was costing him.
Glad you had it done that cheap, but I wouldn't run my CUT with a rotary cutter for less than $40 per hour, especially when I have to haul it to the site. But again, glad it worked for you. /forums/images/graemlins/smile.gif
/ Stump removal #6
I was gonna say same thing , but didn't want to be antagonistic.
Now I'll say it. THAT'S FREAKIN CHEAP! I've got 12ac of work for him tomorrow. You can't get bush hogging done for 25/hr 'round here.
There was another post where TBNer gave 800 for 3hrs of trackhoe work, where I gave 85/hr for same CAT225
Goes to show the wide range of price and the need to shop around.
/ Stump removal #7
</font><font color="blue" class="small">( After two days trying to remove a large (30-35") stump with a Kubota 7610,fel, shovel, and axe, I finally came to my senses and will farm out the job. I have about 25 other stumps to remove. My question is does anyone have an idea what the cost will be to hire someone with a bulldozer? to remove the 25 or so stumps? This is in the Saratoga Springs area of New York. )</font>
My neighbor recently had about 13 stumps removed for about $500. It took about seven hours. They were using some type of large back hoe. This is in Dutchess County, NY.
He originally tried to use my BX-23. It probably would have taken him a year to get them all out.
/ Stump removal #8
Well I'm the guy who was mentioned above that paid too much. I was quoted for the whole job rather than per hour. Maybe you should get a quote of hourly rates at the same time they quote the job. Apparently I paid too much, but well, my other quote was $50 less and it required me to do significantly more work. Next time I'll just go buy a stump grinder for $4000 and use it, and then resell it for $4000.
/ Stump removal #9
</font><font color="blue" class="small">( $25 per hour for a big machine and an operator is dirt cheap. )</font>
You are so correct with that statement. That is why I stress shopping around. I first attempted to remove them myself with an Allmand TLB. But this was truely a waste of time and money.
Again shop around get prices..
Also as stated in other posts, depending on what you want to do, you can rent a stump grinder or have someone come in a grind them.. There was a lad in my area that was grinding stumps for 10-25 dollars per stump depending on size and if he needed to cut the stump down with a chain saw. I watched him do some work on my neighbers property and he made it look easy.. /forums/images/graemlins/grin.gif
/ Stump removal
Received a cost estimate today, the cost to bring the machine is $65 the cost to remove machine is $65 the cost to use machine and driver is $1200---------Total cost $$1330???
I guess the stumps will stay there another 17 years>
/ Stump removal #11
Based upon the previous comments, you may want to consider getting more than one quote before giving up on this.
/ Stump removal #12
Wow, that seems to be a pretty high price for 25 stumps. What kind of machine were they planning to send? The delivery charges didn’t seem too bad but the operating cost was high for here. I can get a D4 dozer and operator for $65 per hour and a D6 for $85 per hour. A larger excavator would be more but would have 25 stumps gone in no time. Did that include removing the stumps from site? That could account for the extra money. I think some more shopping around is called for or having the stumps ground if you will not be building on that site.
How about renting a full size backhoe for a weekend. Even without much backhoe experience you could easily get the stumps dug and pay under half your estimate. If time got short on the rental you could do the clean up with your tractor.
MarkV
/ Stump removal #13
Oh well, we all do "not so smart" things sometimes. A couple questions I always want answered are; the per hour rate and if the per hour rate is based on the machine clock or on-site time. When you make them break it down, it usually results in a very obvious price difference.
/ Stump removal #14
Would pretty much depends on local rates. Our local rental is $250.00 per day (8 hours clock time) x 2 plus $250.00 hauling fee = $750.00 total.. Unless there's something missing, he should be able to hire it out and be done with it for a little less than that. ($85.00 /hr x ~5 plus $200 moving allowance is ~ $625) Last job we hired out was Dirt, tree, and stump removal to a fellow with a JD555 w/backhoe. paid $800.00 cash plus lunch and a snack for 10 hours of clock time. I think the lunch and snack got us a discount /forums/images/graemlins/grin.gif
/ Stump removal #15
</font><font color="blue" class="small">( My dozer weighs over 40,000 pounds and has 168 hp and I park it before wasting time and energy on stumps.
)</font>
with proper technique you should be able to remove anything but the largest stumps with a 40,000 lb machine, our 12,000lb TD9 has taken out stumps well over 2ft with little work, a tilting blade (4 way) is the key to not disturbing lots of soil with a 40,000lb machine you are doing something terribly wrong if you arnt satisfied with its tree stump abilitys.
/ Stump removal #16
I'd even thought of trying to rig up something like a sub soiler to mount to one end of the blade of my TD-9 to just drop along one side to cut roots before I went back at 90 degrees from that cut to push out the root.
I figured I'd kind of copy your blade top attachment method, come straight down the face to below the cutting edge then forward at ~90 degrees. I think that with something like that my TD-9 ought to make a nice root cutter & stump removal machine. /forums/images/graemlins/smile.gif
/ Stump removal #17
sound like a good idea gary, just if it were me i would keep it in the center of the blade since you have a 6 way blade and they are known to be weak for working with the outer corners of the blade, i have seen the frames twisted from digging stumps too hard with the corner of the blade, just gota be carefull as the blade is pretty wide on your machine, looks like a 9 or 10 ft blade to me, but our machine only has an 8ft one, 4 way not 6 way. also there are two basic types of 6 way blades, the ones that have the outer puch frames and the channels that pin over the arms to swing the blade are alot better than the hyd turn ones when it comes to digging stumps and rocks with the blade corners, that being said, dont ya love the TD9 sized machine garry, they are about the perfect size for a larger yard, enough power to do real construction work efficiently, yet still small enough to be used in the woods and be not too hard to work on. in my opinion JD350 and TD6 sized dozer are a bit small for real earthmoving, and D6 cat sized dozers are too big to easily transport without permits and some real heavy parts if you need to work on one, but the TD9s seem to fit the bill nicely for general landclearing, woodsroad building, driveway building, grading, logging etc
/ Stump removal #18
<font color="blue"> "you have a 6 way blade" </font>
Well, so far as I can tell, it's a four way with only the blade lift being hydraulic. The down, of course, is gravity. For my side angle I have to lift the blade, pull a pin on each side and manually turn it then pin it again. I have three options; straight, right or left. I'd guess the angle to be about thirty degrees.
I can change the angle of the blade attack at the cutting edge with large screws at the top and bottom of each blade end. I don't know that I have the ability to angle the blade side to side (raising one corner and lowering another).
I got a pretty good manual with it that addresses everything else pretty well. On this topic it only cautions not to have the blade ends differing in height more than a foot. It offers NOTHING on how to make that happen. /forums/images/graemlins/crazy.gif
It seems yours has more hydraulics than mine from the picture. Any idea what I might need to do or have to tilt my blade side to side? If I could do that I wouldn't hardly need a root ripper. I could just use the blade.
As to the dozer itself, I'm real happy. All I've done thus far is clean up an old barn floor area where the first pole barn burned (before my time there), cure a bad drainage problem and take out a couple small trees. Tomorrow I'm going after some more trees and bushes. /forums/images/graemlins/wink.gif /forums/images/graemlins/smile.gif
/ Stump removal #19
All this heavy equipment seems like overkill!! I just had 20 stumps removed for $190. They were all med sized stumps (aprox 20" across). The guy used a Vermeer 630 B Stump Grinder. Took them down to 3" below the surface and it took about 6 hrs. He charged a $50 set up fee and then $7 a stump. you might want to check this out before you get into the real heavy stuff!! Down here there are guys with stump grinders on every street corner !
/ Stump removal #20
<font color="blue"> 'All this heavy equipment seems like overkill!!" </font>
First, let me welcome you to TBN. /forums/images/graemlins/smile.gif As to your overkill characterization, you say that like it's a bad thing. /forums/images/graemlins/grin.gif
Truth be told, I have a bulldozer and I don't have a Vermeer stump grinder. Were that situation reversed, I'd probably be grinding away. /forums/images/graemlins/wink.gif As it is, I'll use my little dozer. Besides, I think a dozer is more fun. /forums/images/graemlins/cool.gif
MASSEY FERGUSON 240 TRACTOR (A64280)
MASSEY FERGUSON...
JMR mini trailer mover attachment (A61567)
JMR mini trailer...
2015 HAMM H11IX PADFOOT ROLLER (A64279)
2015 HAMM H11IX...
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
2006 Hummer H3 4x4 SUV (A61574)
2006 Hummer H3 4x4...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
