Stx 375 transmission code
   / Stx 375 transmission code #1
smiley53
crowley,louisiana
stx 375
I am having a problem with my STX 375. Whenever it is in drive the tractor will go back into neutral automatically. I then have to put it in park and back into drive and after going about twenty yards it will do it again. It started to throw a transmission code (56004) and it says that the measured transmission output speed does not match the commanded transmission output speed. What could be causing it to throw this code and what could I do to fix it?
   / Stx 375 transmission code #2
Is the speedometer working? I would check the output speed sensor.
2019 WABASH DVLSHPC 53FT DRY VAN TRAILER (A59905)
2019 WABASH...
40 (A52708)
40 (A52708)
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
2013 FORD F-350 FLATBED (A58214)
2013 FORD F-350...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
