Sub Soiler on a 2520?
   / Sub Soiler on a 2520? #1
Gobblin Tom
Western, PA
2011 JD 2520
I was thinking about getting a sub soiled for some wet spots in my yard and my dads yard. Has anyone ever used one with the 2520? Also are there any models that are iMatch compatible??
   / Sub Soiler on a 2520? #2
Mother Deere makes an iMatch compatible subsoiler called the PS10. They may have others too. I don't think any other brand is compatible. Will the 2520 be able to haul it? Yes.
   / Sub Soiler on a 2520? #3
I have used a subsoiler from TSC (King Kutter?) with my 2305 quite a bit for trenching and burying cable. You should have no trouble with your 2520.
   / Sub Soiler on a 2520? #4
I have had a Landpride scarifier SF2566 for 8 years. Originally used behind a JD 5200 (8500 lb operating weight) I could pull all 6 shanks to a depth of 12 inches. I have loaned it out to 3 neighbors and found that a good rule of thumb is the following...you need 1,000 lbs of tractor weight for each shank's max depth of 12 inches. This is in soil that has the usual mix of sod, rocks and tree 'hair' roots. In other words, a 2500 lb tractor can pull 2 or possibly 3 max shanks. The PDF to the User Manual follows and you can find operating techniques and things to avoid. One thing to check is that max lift height of your 3-point allows the beam carrying the shanks to be above ground level with the depth of shank setting you need. Otherwise you will have to shorten the shank setting to get going.
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
30ft Highway Trailer Co. Lowboy (A56438)
30ft Highway...
Honda utv cart (A56859)
Honda utv cart...
2017 Ford Transit 350 Passenger Van (A59230)
2017 Ford Transit...
