subsoiler use
   / subsoiler use #11
7520 said:
I have approx 30 ac of hay field and pasture that has never been plowed or anything. hay production is way down even with lime and fert. would a subsoiler help? how when is the best time to use it. i realiy dont want to tear up the field.how close do you make passes. thanks in advance
My neighbor put in 20 acres of alfalfa last year. He ripped the field early last Sept with a single shank parabolic subsoiler (ripper) using an MF 294 (74hp engine, 56 hp drawbar). The soil was bone dry after 4 months without rain and several months of triple digit temps. That 294 really got a workout.
He ripped the fields on the diagonal to the fence lines on about 3-ft centers. Next he ran a tandem disc over the field several times. Since he planned to used surface irrigation, he used a D7 Cat and a laser leveling box grader to to slope the field.
   / subsoiler use #12
I have a 7 shank ripper that I haven't used in years. I have actually seen better results from using an aerator. A local farm/ranch supply has a 15' Aerway they rent out. I have pulled it over my hay meadows twice a year for the past 3 years and noticed better yields (mostly common bermuda) since doing so. Of course, we also do soil samples and try to keep soil conditions optimal for bermuda. And pulling the Aerway at max angle (make it "till" a little) followed by a 15' chain harrow has certainly helped smooth out the rough spots as well. Our hay cutters used to complain about some of our hay meadows but have quieted down the past couple of years.
   / subsoiler use #13
hudr do you ever have problems with the tines on the aerway the farm i work for had one and we hated it i would spend 2 hours changing tines every night before i could even start tilling if you are going to subsoil you will need a fairly large tractor i have pulled a 4 shank behind a steiger before and the steiger was working in 4th gear and that is about 2-3 mph i have pulled a 6 shank on the same tractor in 6th gear in soil that wasnt nearly as compacted i would think that the subsoiling will help alot it would be the first step you can aerate but that woulndt be as bennificial as deep ripping you could aerate after you deep rip to kinda help prevent compaction a little also for anyone using aerway do not use gennisis tillage tines the are cast not forged and they are junk we broke like 75% of them in one fall and genn till said they were defective so they sent us a new set those were just as bad for anyone that knows anything about metalurgy forged is far superor to cast
sorry about it being so long
brett
   / subsoiler use #14
Sometime ago I asked a similar question as the original and the answer was renovation doesnt perceptibly effect yield. I think though in the presence of severe compaction that might not be true. There are university studies on which this position is based. Intuitively though it makes sense that renovation would have a positive effect...just not in terms of DM/ac. There might be other goals for renovation such as stand longevity. The deeper the roots go the better the crop would fair during hot dry periods + allowing easier migration of water and fertilizer to the roots. It might also allow a field to dry sooner as the water would have a place to drain. Sorry this isnt more coherent but Im just trying to think thru this as I go...mostly for the purpose of discussion.
   / subsoiler use #15
Brett,
I haven't had any trouble w/ the tines ( I am renting the equipment). Of course, improvements have been made. I remember one of the first Aerways they got you had to either weld the new tines on or replace the entire roller. Now the tines mount to an axle and can be changed individually. We have sandy loam soil around here for the most part, so we don't break a lot of tines on rocks and what-not. I normally pull the Aerway w/ a 4320 JD in 3rd or 4th gear. It actually pulls easier in 5th but that is because it raises up out of the ground and you lose the penetration. In really tight soil I drop to 3rd to allow max penetration (the 2 tons of concrete weights help also).
About the ripper; Yes, I guess depending on where your hardpan was a set of rippers would provide quick results, then follow up w/ the aerater.
I saw an ad (Aerway ad, keep in mind) that showed wheat grown in a "ripped" field and then in an "Aerwayed" field. Ripped field root balls grew in line w/ the ripper furrows and plants were a little anemic. Aerwayed field root balls were rounder, fuller and the plants looked better (once again, this was as Aerway ad, so take w/ NaCl).
And yes, the metallurgy on the tines makes a HUGE difference in durability and tine life.
So like everything else, tool to use depends on a variety of factors; soil type, overall comapction, etc, etc.
   / subsoiler use #16
7520.... dig up several areas of your pasture. If you find that the roots are NOT getting into the ground deeply so they can get both moisture and nutrients, then hunt down the reason. If they go down then hit a hardpan and stop... then subsoiling to fix the compaction will help. Some soil does NOT compact and/or need subsoiling.... some does.... you can learn a LOT by digging up the grass and studying what the roots are doing... also by knowing what grasses you have. Some are deep rooted types, others are shallow types. Dig, observe, learn. If you use a subsoiler, beware, it takes huge amounts of horsepower for a single shank....
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
Paint Dryer, Briggs 5.5 (A52384)
Paint Dryer...
2013 Toro Workman HDX Scissor Lift Utility Cart (A51691)
2013 Toro Workman...
2006 Pierce Fire Truck (A51692)
2006 Pierce Fire...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
PAIR OF 607 CHALLENGER PUMPS (A53843)
PAIR OF 607...
