SUDT vs 80-90 for standard trans
   / SUDT vs 80-90 for standard trans #11
The manual says only Kubota UDT or Super UDT.
I have never been satisfied with the data I've been able to obtain explaining why SUDT is worth the price difference between it and UDT. In the end I bit the bullet and put SUDT in for two reasons. The first and worst reason was fear and ignorance. The second, and better reason is that it will be a long time before I have to do this again and even though my hourly usage is low, the hours that I accumulate are usually pretty rough ones so i might as well use the 'good' stuff.
It was very expensive and probably a waste of money but at least I won't have to second guess myself in regard to the well being of the tractor.
   / SUDT vs 80-90 for standard trans #12
   / SUDT vs 80-90 for standard trans #13
If you do not have a recent (last five years production) HST or GST transmission, you do not need SUDT and UDT is fine.
UDT in a manual transmission if fine, but 80-90 gear oil is not.
   / SUDT vs 80-90 for standard trans #14
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
CATERPILLAR H120S HYD HAMMER (A52707)
CATERPILLAR H120S...
Kubota RTV-X900 4x4 Diesel Utility Cart (A55851)
Kubota RTV-X900...
2007 INTERNATIONAL 4300 26FT BOX TRUCK (A56138)
2007 INTERNATIONAL...
SHOP CAGE WITH CONTENTS (A55745)
SHOP CAGE WITH...
