Dargo
Super Member
- Joined
- Mar 6, 2004
- Messages
- 5,981
- Location
- S. IN
- Tractor
- Jinma, Foton, TYM, Belarus, Yanmar, Branson, Montana, Mahindra and maybe some green and orange too.
IslandTractor said:Where are the real world tests and economic analyses?
A good buddy of mine runs 3 different drag cars. He was basically getting 1 season out of his bracket cars and about a half out of his heads up 1/4 mile car. I've spent many hours being free labor learning how to build a drag engine with him. After switching to Red Line oil, when he went to tear down one of his 572ci engines after a season, it showed no measurable wear anywhere. The other car running a 468ci engine was the same; no wear. He finished the season with his other car with no tear down.
Each car had the oil changed after each weekend as usual. Same engines, using the same supplier with the same re-build parts. For years and years, one season and the engines were flat worn out. Now, with Red Line, they show no wear.
Maybe the magic engine fairy visited all of his cars lately and that is why he has seen what he has. If so, then the engine oil had nothing to do with it. Also, if that is true, if your engine in your tractor wears out you don't have to do anything to it either. The engine fairy will come replace it for you.
I've personally seen all the proof I need to see. Based on real world results that I've seen, your estimated percentages of difference are off by several hundred percent.
