suggestions for automatic grease gun
   / suggestions for automatic grease gun #11
I have been eye-balling the Lincoln 14.4V gun for many months now. Are they capable of being filled from a bulk supply with a bulk loader pump?
Yes there's a fitting for bulk fill.
I used mine today on my case backhoe and I like it so far. Seems pretty solid. Much to my shagrin, "Made in China"-of course...... that's really annoying.
   / suggestions for automatic grease gun #13
I b ought the Lincoln 14.4,it worked great the first tube, but I couldn't get grease to come out of the second tube.I tried pressing the primer, but no luck. I held the trigger down for 2 minutes straight still no grease. What am I doing wrong HELP!!!!!!!!!!!!
-mike-
   / suggestions for automatic grease gun #14
I bought the Lincoln 14.4,it worked great the first tube, but I couldn't get grease to come out of the second tube.I tried pressing the primer, but no luck. I held the trigger down for 2 minutes straight still no grease. What am I doing wrong HELP!!!!!!!!!!!!
-mike-
   / suggestions for automatic grease gun #15
I have a Lincoln 12-volt and I'm happy with it. I only got one battery and that is more than adequate for my needs. Just be sure to "burp" the gun when done, otherwise grease finds it way out of places you wouldn't think it could.
I took mine to the local service center thinking I got a lemon, and they told me it needed "burping" by pressing the relief button.
Since doing this, I haven't had any problems and I should have read the manual more closely.
-mike-
Try hooking the female end up to a grease fitting. That worked for me.
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
Bell B30E 30 Ton Articulated Dump Truck (A52377)
Bell B30E 30 Ton...
2008 FORD F450 SERVICE TRUCK (A54607)
2008 FORD F450...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
