Suggestions for pole boom?
   / Suggestions for pole boom? #1
Bob_Trevithick
Platinum Member
Williamson, NY (near Rochester)
JD 4300 MFWD
I've got a JD4300, no FEL (yet!), and need a quick and easy way to lift things on and off the back of a flatbed pickup. Not yet sure *what* things I'll be lifting, so want as high (in both height and weight) as my tractor can handle.
Any specific suggestions? Including hopefully a website where one can be ordered?
How high off the ground should I be able to lift? Can I easily clear the bed of a truck?
I've seen some with anywhere from 500 to 2000 pound lift capacities, and the prices didn't seem much different.. usually in the $100-200 range.
I know this has been discussed in other threads, but I couldn't find any specific reference to one which is well-made and can be ordered easily from a reliable website.
Thanks much,
Bob
   / Suggestions for pole boom? #2
Can you spell FEL?
<font color=blue>Can you spell FEL? </font color=blue>
1) I can't afford one at this time.
2) I want something to keep the thing I'm lifting away from the tractor further so it can't swing and do any damage.
   / Suggestions for pole boom? #4
Bob,
I've got one I built out of some pretty heavy wall 2 1/2" pipe. I copied the design from one I found on my dealers lot. I added some reinforcement in a couple of places and increased the boom length from 80" to 96".
The longer pole makes your tractor lighter on the front but I have always used it with a fairly heavy tractor.
I have no idea what it's capacity is but it will probably pick up more than my tractor would. I have lifted disks, bush hogs and all kinds of stuff out of pickup trucks, off trailers and off the ground.
The trick is to lower the 3ph all the way down and use the top link to adjust the end of the boom down to where you get the maximum lift. I get about 5.5 feet of lift out of mine. A hydraulic top link would make it even better.
Yeah, a fel can do the job better but this does the job for me just as well and a lot cheaper. I would use a fel about once or twice a year - the rest of the time it would just be in the way.
Look around at most any tractor supply place or tractor dealer and pick out the one that best fits your tractor and your needs.
TBone
   / Suggestions for pole boom? #5
Bob,
One place you might look is Agri Supply (1-800-345-0169) <A target="_blank" HREF=http://www.agri-supply.com/>http://www.agri-supply.com/</A>
Chris
   / Suggestions for pole boom? #6
Here's one from Tractor Supply
<A target="_blank" HREF=http://bluebook.tractorsupplyco.com/_pages/166_171.pdf>http://bluebook.tractorsupplyco.com/_pages/166_171.pdf</A>
<font color=blue>One place you might look is Agri Supply..</font color=blue>
Thanks, Chris! I'll have one by next Tuesday. They had a rugged 2000# unit, and I liked the sound of the folks, so what the heck? /w3tcompact/icons/wink.gif I know my JD4300 probably can't take full advantage of the 2000 lb. capacity, having only 2200 lb lift 24" behind the hitch, but who knows about upgrading tractors at some point... /w3tcompact/icons/wink.gif
Appreciate your help!
BTW, does anyone have a picture of one of these handy? I couldn't find a pic on the web site..
Thanks, Folks!
   / Suggestions for pole boom? #8
Bob, here ya go, courtesy of TSC.
<font color=blue>...Bob, here ya go, courtesy of TSC.</font color=blue>
Thanks, Mike.. but actually I meant did anyone have a pic of the specific 2000# unit sold by the Agri-Supply folks. Sorry I wasn't more clear! /w3tcompact/icons/blush.gif
Bob
   / Suggestions for pole boom? #10
Mike, I've looked at those at TSC and they're rated for 1000 pounds, so I guess so, but to tell the truth, the ones I looked at appeared sorta flimsy. Now that's going by looks only so maybe it's stronger than it looked.
2020 FORD F-250 SUPER DUTY (A52472)
2020 FORD F-250...
SHOULE PWD-10 LOT NUMBER 133 (A53084)
SHOULE PWD-10 LOT...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
Husqvarna 120 Chainsaw (A51573)
Husqvarna 120...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
