suggestions on loading a tractor.
   / suggestions on loading a tractor.
Yeah, your trailer is fine.
I think you've already got a good idea how it's going to go down. I totally agree with Gary Fowler. Fatherly respect is a good thing.
Still need pics!!!! Hope you guys have a memorable and enjoyable trip. It'll be something you'll always remember!!!
I will. Should be no later than june, thanks again everyone. He wanted to pull it on his 16', 5 lug axle trailer (3500 an axle I'm guessing), load c tires and the bush hog in the bed of the '82 1/2ton 6.2 diesel pick up pulling the trailer. Thats when I said "I'll just come out dad, don't worry about it". I saw your section for pics like that.
   / suggestions on loading a tractor. #12
Tell your old man to behave in Arizona. That Sheriff out there does not play....
Chris
   / suggestions on loading a tractor. #13
You can come back to this thread and post your pics by clicking on the small icon above your text when you type it. It's the fourth one from the right. I'm not smart enough to attache a picture of the icon..... Place your cursor on it and it'll say "insert image". Then follow instructions.
Use the "My Home" icon at the top of the page when you come back. It shows every thread you've posted on that's had a reply since you were last logged in.
Chris
Can't teach an old dog new tricks.
He isn't in THAT county, but he is going to buy enough property not to have to leave but once a week, if that. That will help his case.
   / suggestions on loading a tractor. #15
First thing you need to do is weigh your trailer and subtract that from the gvwr of the trailer. If your axles are rated at 7200# combined I think you are going to be overweight with just the tractor and loader. Add in a 800# bush hog, the other implements, chains, binders, ect and you are way way over.
As for my tractor, it's a little smaller. 3800# by itself and 4600# with the loader. I have both rear tires filled and that bumps it to 5200# total. If I am hauling just the tractor and loader I back it on my 18' trailer. With my 6' bush hog I pull it on forward.
Chris
That is quite the trailer for hauling quads.
   / suggestions on loading a tractor. #16
Just a thought. You could put the brush hog on standing up to get more trailer real estate
   / suggestions on loading a tractor. #17
My trailer is 2900 with the rack. Im taking the rack off which is 300 putting my trailer at 2600. I have checked the tags on the axles and they are 7200 a piece, so 14400 total.
As far as deck space. The tractor is 11' no loader, the bush hog is 6' (if lifted on sideways) thats 17' (18+ really). I figured thats the only way it would fit. The front axle is at 10'6" rear axle 13'.
I toyed with setting the bush hog on the front with the wheel towards the rear, backing the tractor up hopefully getting some over lap because the bush hog tapers, and putting the bucket and spikes as far up as possible and pray the arms don't hang off.
If the rear is that heavy I might have to back the tractor on to the front and put the bush hog on under the bucket on the rear. As a desert goer I have always test loaded until I found a good fit. Thanks for the input and not bashing to the new guy.
I would test it, but I would start with the spikes up front (perhaps poking through into the A frame area or sideways in the very front?), the back the tractor on carrying the bush hog and set it down on the back of the trailer.
If that didnt work, I might look into doing as GPintheMitten suggested and putting the brush hog on standing up in the front, but there it would be like a large sail.
Sounds like you should have enough deck space to play with location of the tractor to get the balance just right.
Aaron Z
I have a 97 mercury mountaineer as an off road truck. My wife has a quad and my kids ride as well. I was looking for an 18-20' with atleast 5k axles. This popped up for $2k with brand new tires and bearing service. (PO took it to the shop then saw a used trailer on the way home and bought it. I picked it up from the tire shop. lol). I figured it only weighs a few hundred more than what I was looking at before, but I would rather have too much trailer than not enough.
Aaron Z
Thanks for the inputs, I'm pretty good at making stuff fit. I just needed the experience you guy have for the tractor balance, which you have given nicely.. Thanks again.
This is my trailer.I have NEVER, and I do mean EVER towed that trailer with the exploder, it was a photo op only in my driveway. Someone asked how I load my trailer for the desert, so I used the exploder just to hold the trailer still. Please no comments of dangerous towing. Photo239.jpgPhoto240.jpg
BTW I also have a toolbox that goes on the tongue that weighs 500lbs with a winch, recovery, etc to offset the merc being so far back. It isn't in the pic. And I'm taking the rack off.
2008 KALMER 4X2 SPOTTER TRUCK (A54756)
2008 KALMER 4X2...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
Cowboy Wooden Statue (A55853)
Cowboy Wooden...
66in Bucket Skid Steer Attachment (A55851)
66in Bucket Skid...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55315)
PENDING SELLER...
2014 Ford Explorer AWD SUV (A53424)
2014 Ford Explorer...
