Suitcase weights and front end loader
   / Suitcase weights and front end loader #11
JD weights are approx $1 per pound if that saves you some money. They have the built in handle at the top and thus the name suitcase weights. $42 for a 42# weight.
   / Suitcase weights and front end loader #12
   / Suitcase weights and front end loader #13
I just looked at the quote ant my dealer is charging $70 for 55#. Sounds high to me.
   / Suitcase weights and front end loader #14
   / Suitcase weights and front end loader #15
</font><font color="blue" class="small">( I just looked at the quote ant my dealer is charging $70 for 55#. Sounds high to me.)</font>
Me to. Nearly $1.50 per pound. The tractor itself cost less than $3.00 a pound. My rotary cutter was about a buck a pound, my box blade about $1.25. /forums/images/graemlins/grin.gif
   / Suitcase weights and front end loader #16
I paid about 75$ per 55lb weight. That includes a mounting kit which is basically a bolt, nut and some washers to hold it onto the bumper. They also have a hole in them which I put an 8" threaded rod through to help keep them tight together.
They recommended 220lbs for my L3830 with a 5ft brush cutter on back.
   / Suitcase weights and front end loader #19
After I posted about removing the weights to put on the loader I looked at my tractor and I had left the weights on and had the loader on! It was setting on the weights. I thought it went on kind of strange.
Didn't hurt anything, I just removed the weights. The loader won't go down below ground level with the weights on.
ksmmoto
   / Suitcase weights and front end loader #20
ksmmoto
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
2003 MACK 1M2 DUMP TRUCK (A60430)
2003 MACK 1M2 DUMP...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60430)
KNOW BEFORE YOU...
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
1408 (A57192)
1408 (A57192)
Honda utv cart (A56859)
Honda utv cart...
