Sulphur in water
   / Sulphur in water #1
sweeter
Central Western OH
JD 5625 JD 2305 tlb JD 850 XUV
Hey guys....I've been trying to rid my well of the horrible sulphur smell as to date I have tried the following fixes. I have a h2o softener, whole house filter with carbon filter, I've removed the mag pipe from the softener and pour bleach into the well regularly. I am trying to avoid getting one of those expensive sulphur filters that culligan and some other the other companies sell for 2000 and up. If anyone has any ideas I'm all ears.
Thanks
Sweeter
   / Sulphur in water #3
FWIW, down in Florida, they use aerators. It is a big tank with screened vents open to the atmosphere. The hydrogen sulfide gasses off due to the large surface area of the water. The downside is you need a second pump. The well pump fills the aerator and a second pump supplies the water pressure. Limit switches control the filling of the aerator, as I understand it.
   / Sulphur in water #4
Water from my well also has a high sulpher content but you'd never know it at the tap. I have an ozone system from Triple O Systems - Ozone Water Treatment Systems. I thought it would be a bunch of hokum when it was first proposed but it works like a charm.
Mine consists of a small ozone generator in the pump house, a large plastic half burried cistern outside (don't know the exact capacity, but it's big), and a filter and bubbler that hangs in the cistern.
On one side of the cistern is the usual well pump that keeps the cistern full. Between the cistern and the house a pressure tank and a jet pump. So you end up needing an additional pump because the cistern essentially becomes the "well" that you pump out of.
I couldn't be happier with this solution.
   / Sulphur in water
Thanks for the info guys...I also did a search on here after I placed my post and found some more info as well.
Thanks
Sweeter
   / Sulphur in water #6
I read somewhere that a builup (fungus?) in your hot water heater on the heater element can make the sulphur smell even worse.
you may want to examine and change out the heater element. It may help and it will be a lot cheaper than anything else you can try
   / Sulphur in water #7
If you have not found the earlier posts on this subject.....
I use an aquarium bubbler and a 3.5" chassis fan running 24/7
in my water tank. It easily removes the dissolved H2S gas.
You have to have a no-pressure tank, as mentioned.
Some of my neighbors have worse probs (Mn and Fe) and so use
the Ozonator, like Triple O sells.
BTW, even my NEW electric water heater makes lots of noise and
if I am not keeping up with aeration, the hot water stinks first.
   / Sulphur in water #8
Sweeter,
When we first bought this house we had the same problem. I turned out to be a problem with the expansion tank. It turned out the rubber they used seemed to be the perfect medium for a type of bacteria that produced hydrogen sulfide gas. After some research, we found there was a recall on the tank and it was replaced for free. Problem was solved!!!! It might be something to look into.
Gary
   / Sulphur in water #9
Are you sure it's sulfur? The water at my house smells like sulfur to but that's not what it is. I get my water tested on a regular basis and mine alway's shows a high manganese (sp?) level. Smells just like sulfur/rotten eggs. I to have a water softener and it does nothing for the smell. I installed a charcoal water filter on the kitchen sink and it removes it but to install one of those filters on the whole house would mean I would probably have to change the filter cartridge on a weekly basis. The plug up fairly fast.
If you have not had your water tested by a lab yet I would. Make sure your dealing with sulfur before you get to involved in trying to get rid of it.
   / Sulphur in water #10
There is some sort of rod in hot water heaters that can cause a sulpher smell. In my cabin we get this smell only with the hot water and only with the first tankful. After that, no smell. Someone said you could remove this rod, but others say that of you do you will get corrosion?
   / Sulphur in water #11
Most rods are magnesium which go into the H2O tank. The heat and the metal react with the H2S gasses to have them smell.
Most times you replace these with an Aluminum anode rod to limit the reactions. It still works the same however it keeps your smell down.
Don't take the rod out completely. If you do then the water starts eating at your tank and eventually it'll leak.
I'm on my 2nd rod on a 3yr old tank.
   / Sulphur in water #12
Dr George, that is the sacrificial anode rod, typically made of magnesium. It's job in the hot water tank is to corrode due to electrolysis, instead of the tank corroding.
If a magnesium anode causes your well water to smell, you can try replacing it with an aluminum anode, or remove it all together (although removing it WILL shorten the life of the tank from approximately 10 years [doing no maintainance] to around half of that).
My well water has a very high iron content. This causes the hot water to smell bad. I tried replacing the anode with an aluminum one, but it didn't change. I've found that the only way to keep the hot water smell to a minimum is to dump & flush the hot water tank, & wire brush the anode, 3 times/year.
Here's a tip that will make your hot water tank last up to 3 times longer than "normal" (normal being; you do nothing): At least once every 2 years, remove the anode & wire brush it! After 7-8 years, REPLACE IT! A new anode isn't inexpensive (at around $40-$50), but compared to the cost of replacing the tank, especially if you can't do it yourself, it's cheap insurance & will save you money.
   / Sulphur in water #13
There are special, albeit simple, filters for removing manganese. Alternatively, pumping it into a cistern with aeration will remove it, if the water has enough chance to stand.
Given the health hazards, you probably want to do something about it.
All the best,
Peter
   / Sulphur in water #14
The road in treating the HS in my water has been long and bumpy. Aeration did not work, and chlorine wasn't feasible in that one gallon of 12% would treat 80 gallons of water. I've since built an ozone system utilizing an oxygen generator that feeds an 8 g/hr o3 generator, that then feeds the gas thru a Mazzei injector, and then mixes in a static inline mixer, and then being cleansed by a filtration system. Getting all this stuff to work together was a lesson in persistence, however I'm now able to treat 50 gallons per hour, utilizing a 1200 treatment tank. Once the water is transfered into the settlement tank, it is then chlorinated prior to entering the pressure pump, and then removed by the the carbon filter down stream.
HS bacteria is what turns the water black, and can irrervisibly lodge in the carbon filter, and become trapped in the softener's resin and hot water heater. Draw some water off the heater, and if it's black then the bacteria has inflitrated the entire water system.
If you need the specifics or more info, send a PM.
Mark
   / Sulphur in water #15
A hot water only odor of H2S is caused by a combination of things. You need some sulfate in the water. Then some SRB (sulfate reducing bacteria, nonharmful to humans and pets) and an anode rod (material wise) that the SRB can get some hydrogen from. Remove any one of the three and the odor goes away.
Gary
Quality Water Associates
   / Sulphur in water #16
Don't forget there is a simple inverse relationship between dissolved gases and
water. A cool glass of water may not smell of H2S, but heat it a bit and
the dissolved gas goes out of solution and you then smell it. That is my
situation, and the first indication that my tank fan and/or bubbler has failed.
I smell it in the hot water first.
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2019 Chevrolet Tahoe SUV (A59231)
2019 Chevrolet...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
2021 FORD F-150 STX CREW CAB TRUCK (A59823)
2021 FORD F-150...
2017 Har-Tru CourtPac Tennis Court Roller (A59228)
2017 Har-Tru...
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
