Toplink Summit Hydraulic Multiplier
   / Summit Hydraulic Multiplier #1
Red Horse
Bolton, MA
Deere 655ZTrak, Deere 4720 Cab, 400 X LT 155
I was thinking of getting a hydraulic top link for use on my 72" box blade (tractor is a 4720 Deere) Then I thought might be nice to have a hydraulic side link so I could cut swales vs jumping on and off to adjust manual links.
anyone have any experience with the Summit multiplier? I went on line and it looks like the kit is like $345.
Any opinions or suggestions?
Thx for ther link. I hvae a cab tractor and a manual is not a good option. I have a LandPride power rake and it is set up with a manual diverter- one way controls the angle of the rake and then the second function works the scarifier attachment. Not that big of a deal to jump out and switch as you are usually using one tool or the other but I would like this for a box blade to control upper link as well as side lift link. those you would want flexibility to use both when for example you are cutting a swale.
   / Summit Hydraulic Multiplier #4
Here is our Diverter Valve on the rear of a 4720 for a TnT setup:
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
John Deere 1025R (A53317)
John Deere 1025R...
2004 INTERNATIONAL 7400 20FT TANDEM AXLE FLAT BED (A59575)
2004 INTERNATIONAL...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
Pallet of 10 Chains and 5 Binders (A57453)
Pallet of 10...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
